BT Homehub 4 Wireless connection issue
- BT Homehub 4 Wireless connection issue
29-01-2015 2:40 PM
I am connected to PlusNet fibre using an Openreach modem and BT Home Hub 4 router, most of the time without issue.
On occasion the devices which wirelessly use the 2.4ghz connection lose connectivity to the internet. This seems to happen only when a particular (neighbours?) SSID is visible. I have tried changing the channel selection from Automatic (Smart Wireless) to the best channel found using Wifi Analyser. When I do this, after applying the change I cannot see my 2.4ghz SSID on any device (even if I reboot the router). I do not have any issue with the 5ghz connection.
Any ideas of the best way to resolve this please, right now I am thinking new router?
Message 1 of 4
(903 Views)
3 REPLIES 3
Re: BT Homehub 4 Wireless connection issue
29-01-2015 4:17 PM
Message 2 of 4
(532 Views)
29-01-2015 4:22 PM
Have you by any chance changed to channel 13 or 14?
If you select channels 13 or 14 (valid in UK & Europe but not USA where only channels 1 to 12 are allowed) some equipment (using USA spec.) will no longer see the signal.
Call me 'w23'
Message 3 of 4
(532 Views)
29-01-2015 4:26 PM
I was trying to change to channel 6 which appeared the strongest
Message 4 of 4
(532 Views)
