Saving changes to Tumblr blog
- Everything else
- Saving changes to Tumblr blog
18-03-2011 3:49 PM
I m having time out problems with Plusnet Tumblr interface, both sides blaming the others engineers. What happens is that I go into the cutomise blog panels, change the settings that I want and then find that it will not save up to the blog host. Blog host says that it is the plusnet interface, plusnet says ask here as it is beyond them. Anyone got any ideas? The image is of the webpage showing where we get stuck.
Message 1 of 2
(1,951 Views)
1 REPLY 1
Re: Saving changes to Tumblr blog
19-03-2011 9:56 PM
What do you mean "Plusnet Interface"?
Message 2 of 2
(333 Views)
- Everything else
