POST problems fixed?
- Everything else
- POST problems fixed?
19-03-2010 1:25 PM
Afternoon guys,
As per the FAQ here.
[quote author="CGI FAQ"]11) My webforms have stopped working
If you have a webform that is reliant on the POST method then you may find that it has stopped working. This is due to way that certain URLs are rewritten on our filesystem and causes problems where the $PHP_SELF or $_SERVER['PHP_SELF'] variables are in use. You'll find more detail about this here. We're hoping to fix this however in the meantime you can use $_SERVER['SCRIPT_URL'] in place of $PHP_SELF or $_SERVER['PHP_SELF'], which should resolve the issue.
After a bit of work, we think this might be fixed now so I'd much appreciated it if those having problems could have a play around with things and let me know how they get on?
Message 1 of 5
(2,741 Views)
4 REPLIES 4
Re: POST problems fixed?
19-03-2010 2:27 PM
Bob
A Timely post. If this is slightly OT I apologise. I'm doing something I've not done before namely setting up a contact form on a website for my son in law. I'm testing the code using my website www,jdcarea1.org hosted in my web space. The form posts fine and I receive the information but REDIRECT is not working.
I've used the generic script posted here elswhere , modifying the form code to point to it. However I get a generic redirect page rather than the formatted page I specified.
Having seen references to redirect not working in other topics what is the current state of play?
Thanks for any help
David.
Thanks for any help
David.
Message 2 of 5
(725 Views)
19-03-2010 3:53 PM
Quote from: Bob [quote author="CGI FAQ"]11) My webforms have stopped working
If you have a webform that is reliant on the POST method then you may find that it has stopped working. This is due to way that certain URLs are rewritten on our filesystem and causes problems where the $PHP_SELF or $_SERVER['PHP_SELF'] variables are in use.…
Using $_SERVER['PHP_SELF'] does work now, though /~username appears in the URL shown in the browser address window after form submission - perhaps not what users would like to happen.
David
David
Message 3 of 5
(725 Views)
20-03-2010 2:28 PM
Quote Bob
Thanks for any help
Bob
Ignor my drivel above. Just proving my numpty status
The word is syntax not Syntax - Heh Ho, I've fixed it any way
Message 4 of 5
(725 Views)
21-03-2010 10:48 PM
I like it. There's a neat bit of scripting behind that fix. The /~username in the url isn't ideal, particularly with a hosted domain, but an unfixed trailing slash does the same. The fix restores functionality, giving users the chance to fix any rogue variables while a site works rather than while it doesn't.
Gabe
Gabe
Message 5 of 5
(725 Views)
