PN IPS TAG
paulcarl
PN IPS TAG
I am planning to transfer my domain from PlusNet to IONOS.
They require the IPS TAG currently assigned to my domain.
I cant find this anywhere on the PlusNet management portal.
How can I get this or where can I find it?
A call to support to was no use, they have no IDEA how to transfer domains, said Net OPS do this but you are unable to talk to them.
Some support this is!
Help anyone?
Tags (1)
3 REPLIES 3
Fixes: 411
Re: PN IPS TAG
Sounds a bit strange, normally you give the existing registrar the IPSTAG for the new one!
Anyway you can get it from a whois lookup, it almost certainly FOREC9
Fixes: 162
Re: PN IPS TAG
Usually the CURRENT holder changes the ISP tag to the new holder.
That is Plusnet needs to be asked to change the tag FROM Force9 to whatever the new owner specified.
adamwalker
Fixes: 221
Re: PN IPS TAG
Hi @paulcarl, I can sort that out for you. Can you send me a PM with your username, the domain in question and the IPSTAG please?
 Adam Walker
