Domain name change
- Everything else
- Domain name change
Domain name change
17-02-2014 4:06 PM
I am in the process of moving over to Plusnet, and I am not happy with the domain name I have chosen when I was asked for one. Is it possible to change it at this stage or am I now stuck with it. Any help or advice/suggestions would be gratefully received.
Message 1 of 7
(1,222 Views)
6 REPLIES 6
Re: Domain name change
17-02-2014 4:23 PM
It's not going to be easy, even if it is possible. What's the main reason you're wanting to change it?
Message 2 of 7
(639 Views)
17-02-2014 7:54 PM
Thanks for your quick reply. It sounds so naff and I could have done much better if I had a bit more time to think.
Message 3 of 7
(639 Views)
17-02-2014 10:43 PM
Do you only use it for email addresses?
David
Message 4 of 7
(639 Views)
18-02-2014 8:26 AM
Yes, just for my email and a new address for my wife, that's all
Message 5 of 7
(639 Views)
18-02-2014 8:37 AM
Why don't you register a domain of your own and have the email forwarded to Plusnet? Then if you move to a different ISP you can keep the same email address and just change to forwarding to your new ISP.
Message 6 of 7
(639 Views)
18-02-2014 10:19 AM
We could probably provide you with a second email account, however jelv's suggested is certainly more favourable and is likely to cause you less problems in the long term.
Message 7 of 7
(639 Views)
