emails will not send on my ipad
geoffsp
I can receive emails but cannot send emails on my ipad. The model is A1416. When I try to send, I get the message "the username or password for 'SMPT:username@relay.plus.net'  is incorrect. I have checked the username and password and they are correct and the same as for the incoming server.
11 REPLIES 11
Lwio
Re: emails will not send on my ipad
I had a similar occurrence with my iPad a month ago. I tried removing the email account (google) and reinstating it. No use. I then just erased the iPad and started from scratch. That worked. I didn’t have anything important on it as I just used it for ebooks so it was easy to erase. You could try backing up via iTunes to a computer or iCloud and restoring it.
Strat
Fixes: 565
Moderator's note:
Topic moved from 'General Chat' to 'Email'.
MatthewWheeler
Fixes: 480
Sorry to hear this.
Have you managed to carry out the advice above?
 Matthew Wheeler
geoffsp
Not yet. I am a bit busy on other things at the moment.
EmilyD
Fixes: 117
Hi @geoffsp,
No problem at all, please just do this whenever it's convenient for you and let us know if this doesn't resolve the issue.
 Emily D
frank3
I have a similar issue with my iPad mini and iphone6. I removed the account; set it up again; sent one email and then couldn’t send another email?
The issue only affects sending email.
I have not been able to check the port number for sending email as the online guide doesn’t work for me.
MatthewWheeler
Fixes: 480
Sorry to hear that @frank3
Have you updated all the devices in question to iOS12 recently by any chance?
 Matthew Wheeler
spraxyt
Resting Legend
Fixes: 75
With iPads and iPhone6, to check outgoing server settings do the following.
From the Home screen, find and tap Settings
Tap Passwords & Accounts, then tap an account in the Accounts list
Tap the Account line under IMAP
IMAP Account information and Incoming Mail Server settins should be seen
Below that is Outgoing Mail Server, tap the SMTP line
The Primary Server line should say relay.plus.net and On. Tap this
The Server slider should be green with Outgoing Mail Server information below
This should be Host Name relay.plus.net
Username accountname or accountname+mailboxname as appropriate
Password for accountname or mailboxname depending on username
Use SSL slider grey (turned off)
Authentication Password
Server Port 587
Tap Done when the settings are correct then tap < Account to go back to the Account page
Tap Advanced then set Mailbox Behaviours
Tap Drafts, Sent and Deleted Mailboxes in turn and in the On The Server section
Tap Drafts then <Advanced, Sent then <Advanced, Deleted then <Advanced respectively
Under Move Discarded Messages Into make sure there is a tick against Deleted Mailbox
Tap < Account to go back then Done
Tap < Accounts and < Settings to return to the top level.
David
moemoff
I had the same problem. Had updated to the new IOS 12.01. It seems SSL was green. Simply turned it off and it now works for sending.
frank3
Thanks David,
I have updated both iPhone and iPad mini to 12.0.1 but the issue pre-dates the update.
After my message I once again deleted and then re-installed my account.
In following your advice all is well until I reach “On The Server” at which point no sub-menu appears when I tap on Drafts or on Sent or on Deleted. All I can achieve is to move the ‘tick’ around.
After I have sent my ‘first’ message with this re-installed account I will check to see if any settings change.
spraxyt
Resting Legend
Fixes: 75
@frank3 wrote:In following your advice all is well until I reach “On The Server” at which point no sub-menu appears when I tap on Drafts or on Sent or on Deleted. All I can achieve is to move the ‘tick’ around..
There isn't a sub-menu; moving the tick is what happens, it sets that folder on the server to hold messages fitting the description (Drafts, Sent or Deleted respectively).
The < Advanced action is top left to take you back to the previous screen so after setting Drafts you can set Sent (and return) then Deleted (and return).
By default with new accounts Drafts, Sent and Deleted messages are kept on the local device - which is not what most users want. Changing the behaviour as described ensures the relevant folders on the server are used (for managing within the Mail app or webmail for example)..
David
