Icons under member details
Anotherone
Champion
Fixes: 21
Re: Icons under member details
Quote from: Townman
If as suggested by AO that this is a McAfee issue then I'd be seeing it everywhere, which I do not.  It only seems to involve the image which appears at the bottom of the forum screens, which to be honest I rarely scroll to.
Quote from: Anotherone
I don't think it was a server problem either ejs otherwise more of us would have seen similar things at some point. I'd wager a small bet that McAfee had a bearing on this ............... I suspect that the occasional issues that we see with the forum (recorded in the many posts on this board) are possibly what triggers the image problem in combination with the aforementioned.
To be crystal clear, I have highlighted what I said. Your cache is definitely the issue, you've said as much. The problem is most likely triggered by issues with these forums as mentioned, in conjunction with something related to McAfee. I agree with ejs, there is inadequate evidence to draw the conclusions you have, the evidence does not point to the server, in fact it points to the contrary.
