Phone line noisy and internet speeds terrible
- Business
- Phone line noisy and internet speeds terrible
25-01-2015 8:34 PM
Hi
Please can you test my phone line as it very noisy and the internet is barely usable.
BT were working up a pole the other day and ever since the internet has gone down hill.
I wish they would sort the lines out as its non stop problems.
Regards
Chris
Regards
Chris
Message 1 of 4
(1,075 Views)
3 REPLIES 3
Re: Phone line noisy and internet speeds terrible
25-01-2015 10:18 PM
System Up Time 08:19:03
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 65248 64394 0 1259 5600 01:49:06
LAN 10M/100M 168660 205493 0 1256 1417 08:18:59
WLAN 11M/54M 274284 261994 0 8133 1261 08:18:49
ADSL Link Downstream Upstream
Connection Speed 384 kbps 448 kbps
Line Attenuation 46 db 13 db
Noise Margin 16 db 14 db
Message 2 of 4
(455 Views)
25-01-2015 10:24 PM
If you have phone line that is hissing or crackling then best just to raise a phone fault manually via the website or by phoning them as its unlikely any agents will see this till tomorrow
FTTP 500 regrade from Tues 28th November
Message 3 of 4
(455 Views)
25-01-2015 11:02 PM
Hi Gus
Thanks for the advice.
Called plusnet and an engineer will be out in the morning.
Many Thanks
Chris
Many Thanks
Chris
Message 4 of 4
(455 Views)
- Business
