wifi radio connection problem
- wifi radio connection problem
18-10-2011 7:58 PM
I cannot connect my new Roberts wifi radio to the network and they say it is a problem with the Thomson TG585v8 router. Can anyone help please?
Message 1 of 2
(508 Views)
1 REPLY 1
Re: wifi radio connection problem
18-10-2011 10:23 PM
You might need to break it down into the steps you've tried and where you're coming unstuck. Presumably at some stage you have to search for what wifi networks are available - does your network appear in the list?
What model is it?
Mathew
What model is it?
Mathew
Message 2 of 2
(248 Views)
