unexplained usage shown up
- unexplained usage shown up
14-06-2012 7:34 AM
Im not to worried as it was off peak and im on unlimited just in the future if I was to move. Packages thats all
Re: unexplained usage shown up
14-06-2012 9:12 AM
PS have you tried drilling in to see what type of usage it was? i.e web/gaming etc also looking when the usage was incurred may help you.
14-06-2012 11:20 AM
14-06-2012 11:24 AM
One option to dig even deeper would be to perhaps install wireshark as from looking at the logs we should be able to see a more detailed view of any further usage: http://www.wireshark.org/
EDIT: rather than wireshark networx would be much more appropriate to analysing network protocols and perhaps helping to identify problems with traffic management rather than usage: http://www.softperfect.com/products/networx/
14-06-2012 12:42 PM
14-06-2012 1:20 PM
Quote 1gb for p2p
if you're using Peer2Peer this is most likely what the usage actually is at the moment so you might want to turn P2P off to see if that stops the unidentified usage from being accrued. Also it would be worth making your wireless network is secure.
Adam
14-06-2012 2:04 PM
14-06-2012 2:12 PM
What OS (or type of phone) is it, Android, Apple?
Are you still seeing data usage through the day that seems more than what you are using it for?
14-06-2012 10:28 PM
15-06-2012 9:24 AM
Quote I think the p2p might be my sky anytime plus
That's not usually classed as p2p, the best thing I could recommend at the moment is to give networx a go when you're able to use a PC on your connection.
15-06-2012 10:00 AM
15-06-2012 10:26 AM
Quote sky anytime plus
having never used that I didn't realise this, but I've been made aware that sky anytime plus is very bandwidth intensive so that is most likely to blame for the 7gb used.
