router probs again
- router probs again
router probs again
13-03-2012 10:16 AM
Date 13/03/12 10:03
Download speed achieved during the test was - 3.68 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 5.05 Mbps
Upload speed achieved during the test was - 122Kbps
Additional Information:
Upstream Rate IP profile on your line is - 448 Kbps
Re: router probs again
13-03-2012 10:44 AM
Today 10:42
955 kbps (119kB/s)
134 kbps (16.8kB/s)
Share
Today 09:50
3584 kbps (448kB/s)
166 kbps (20.8kB/s)
Share
Yesterday 23:56
3169 kbps (396kB/s)
378 kbps (47.3kB/s)
13-03-2012 4:01 PM
Are the results wired or wireless? Do you notice a difference in the wired v wireless speed?
Jojo
13-03-2012 7:50 PM
13-03-2012 10:29 PM
Down Up
3612 370
Wireless results are
2044 146
1263 95
This is about my usual speeds
hope this helps. Ted
14-03-2012 12:59 PM
Normally with this issue the downstream speed wont be affected. Yours seem to drop a lot, so I'm not 100% convinced. I'd suggest using something like inSSIDer to see if the wireless channel you're on has any interference on it.
Jojo
14-03-2012 4:52 PM
What do you make of these router stats
Uptime:
1 day, 7:53:00
DSL Type:
G.992.1 annex A
Channel mode:
Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]:
1,112 / 5,635
448 / 5,568
Data Transferred (Sent/Received) [kB/MB]:
0.00 / 897.97
Output Power (Up/Down) [dBm]:
12.5 / 19.5
Line Attenuation (Up/Down) [dB]:
26.5 / 44.0
SN Margin (Up/Down) [dB]:
26.0 / 10.0
and my results from BT speedtester
Download speed achieved during the test was - 3.22 Mbps
Upload speed achieved during the test was - 87Kbps
15-03-2012 8:51 AM
Just had a look at your line and have been able to lift your profile a bit to 4900 to allow for your new BT IP profile. This should take effect shortly.
For help with changing the wireless channel we have a guide here
Hope that helps.
Jojo
18-03-2012 4:41 PM
All of above seems to point to a router fault even though the router is a new PN thomson v8 , I was advised on here that there is a known fault on these routers, which involves slow up speed. Can any one say if a differant router from a online purchase may solve the issue. Cant think why (if this is the case) PN are supplying routers to solve problems when the new router is just causing new ones. Ted
19-03-2012 1:36 PM
Forgive me, I didn't realise you were talking about upload speeds. Are you getting slow upload speeds over ethernet, wireless or both.
Jojo
20-03-2012 10:36 AM
wireless
Date 17/03/12 00:28
Download speed achieved during the test was - 4.49 Mbps
IP Profile for your line is - 4.91 Mbps
Upload speed achieved during the test was - 150Kbps
Upstream Rate IP profile on your line is - 448 kbps
wired
Date 20/03/12 10:05
Download speed achieved during the test was - 4.17 Mbps
IP Profile for your line is - 5.11 Mbps
Upload speed achieved during the test was - 356Kbps
20-03-2012 11:49 AM
I'll get you a different router out.
Jojo
20-03-2012 8:03 PM
21-03-2012 10:16 PM
Date 21/03/12 22:08
Download speed achieved during the test was - 5.08 Mbps
IP Profile for your line is - 5.39 Mbps
Upload speed achieved during the test was - 382Kbps
Best speeds ive had with PN since I joined
Thanks to Jojo and all the others that helped, this is a feather in the cap of PN. Ted.
22-03-2012 11:47 AM
