*really* slow downloads from adobe.com? 6hrs 23 minutes for a 248mb file!
- *really* slow downloads from adobe.com? 6hrs 23 mi...
21-04-2009 8:38 PM
also, is there a list of sites which plusnet apply traffic management to specifically, which is publicly available?
Re: *really* slow downloads from adobe.com? 6hrs 23 minutes for a 248mb file!
21-04-2009 8:49 PM
What package are you on?
21-04-2009 8:52 PM
21-04-2009 8:52 PM
A lot of sites use the CDN such as Akami and Limelight for downloads, this includes MS so you may well see this throttled.
Have a look here http://www.kitz.co.uk/isp/plusnet_shaping.htm for expected speeds, though if the network is under heavy load it is further throttled.
21-04-2009 8:58 PM
Probably best download it later then!
21-04-2009 9:04 PM
21-04-2009 9:14 PM
21-04-2009 9:16 PM
21-04-2009 9:40 PM
i've tried to download adobe pdf reader and it's coming down at about 5kbps a second, which is quite strange. i did go over my allowance last month - is it possible it hasn't been reset properly and some sites are being disproportionally throttled?
downloading from my plusnet webspace is much faster (although about half of what i'd expect normally, but could be contention?)
21-04-2009 9:51 PM
21-04-2009 9:53 PM
just for reference, here's my speed test results
anywhere over 3000kbps is normal for me.
21-04-2009 10:12 PM
22-04-2009 12:06 AM
any way wireshark picks the pdf download up as download servers(0x60)
a88-221-26-24.deploy.akamaitechnologies.com
ISP: AKAMAI TECHNOLOGIES
Organization: AKAMAI TECHNOLOGIES
Proxy: None detected
Type: Unknown
28-04-2009 2:49 AM
28-04-2009 3:03 AM
