really slow connection since install #66427703
- really slow connection since install #66427703
28-02-2013 8:06 PM
plusnet quoted speeds of 72 for me and since i have been installed i hae never been over 38 mbps
tonight it is running even lower at 8-mbps down and 3 upload
i heard that a lot of people have been on the wrong package and fid it odd that my bext door neighbour is running at 82 meg and i have been nowhere near in the past 7 days
raised a speed ticket #66427703
please help
Re: really slow connection since install #66427703
01-03-2013 9:26 AM
Welcome to our community forums,
I've had a look over your connection and your line is syncing in the high 70Mb/s and your profile is set correctly to match that. Are you currently connecting wired or wireless?
Chris
01-03-2013 9:35 AM
both wireless and wired are giving approx 37-38mbps download this morning( my router is right next to where i usually use my laptop and 1.5-2mbps u/l. A vast improvement on last night but the same as it has been since we had it installed.
Was quoted 80-89 by the BT guy (who advised that our area is super quick due to location) and 72 i think by yourselves but it has never been anywhere near that speed - seems to me like it is on the 40mbps as it has never been over 38-39
Cheers for getting back to me
Lee
01-03-2013 12:21 PM
01-03-2013 2:35 PM
cheers
01-03-2013 8:58 PM
still getting really low speeds
frustrating...
01-03-2013 8:59 PM
getting mixed information as to whether to leave it on constantly especially in the first week or so or to restart if it is a low speed
cheers
01-03-2013 9:37 PM
1 best effort test
Download speedachieved during the test was - 10.24 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
2 upstream test
Upload speed achieved during the test was - 4.64Mbps
someone please help
02-03-2013 8:44 AM
If the latter, then you may well be suffering from this issue. The temporary solution is to drop your PPPoE connection in the router management page (don't touch the modem), count to 20 then re-establish it again. This should hopefully have the effect of connecting you to a different Plusnet gateway. You can find out which gateway you are connected to by looking here. The slow-down problem only occurs during peak hours and only seems to affect some gateways (maybe!). Hopefully PN will get to the bottom of the fault and fix it very soon.
If you still have low throughput this morning, you'll probably need to log a fault at faults.plus.net.
02-03-2013 10:33 AM
connection was running at 88mbps this morning so i think it is the issue you refer to
How exactly do you drop the PPPoE connection?
Navigate to the router IP address, login and then what - excuse but im not exactly savvy when it comes to the router.
thanks again
02-03-2013 12:04 PM
I assume you're using Plusnet's TG582n router. I'm not using it, but from memory after you've logged in there is a link in the menu at the left labelled Internet or something like that. Click that menu and you should see a button to disconnect the PPP connection. Click that. Wait 30 seconds and then click to connect.
If I've got it wrong, I'm sure one of the experts here will chip in with the correct instructions
02-03-2013 1:25 PM
This guide shows you what you are looking for.
In the Broadband Connection box, Click the Disconnect bnutton,wait 30 secs and then Click Connect to re-establish a PPPoE session.
HTH.
02-03-2013 1:35 PM
02-03-2013 2:41 PM
hopefully it stays this way (all day) and ill be happy
