profile
- profile
profile
07-03-2013 4:20 PM
Hi could you raise my profile stuck a 4.60mbps sync is 6.04mbps
thanks
thanks
Message 1 of 5
(873 Views)
4 REPLIES 4
Re: profile
07-03-2013 4:35 PM
I've just updated that for you
Message 2 of 5
(576 Views)
Re: profile
07-03-2013 4:44 PM
Hi Chris,
Could you get my BTW IP Profile raised again please... It was on 77.44 Mbps but I had to change modem cable to a shorter one and I obviously didnt wait long enough so it has been reduced to 67.17 Mbps which I am maxing out when its not peak times.. Prior to changing the cable everything was stable and running like a rocket ship
Message 3 of 5
(576 Views)
Re: profile
07-03-2013 5:05 PM
We aren't able to change profiles on FTTC I'm afraid, it would require an engineers visit.
Having said that, your syncing at 69.4Mbps and your speed profile is set correctly (40M-80M) so there shouldn't be any issues.
The IP Profile might increase once you've had a solid connection for a little more than 72 hours.
Message 4 of 5
(576 Views)
Re: profile
07-03-2013 5:08 PM
Ok Thanks Chris
Message 5 of 5
(576 Views)
