plusnet is worst internet provider in town
- plusnet is worst internet provider in town
21-04-2013 5:25 PM
Hi all,
It seems plus net is worst internet provider I have used so far. Its been 3rd week and im without internet. The worst part is guys in call centre either not understand problem or dont want to fix it.
After 3 weeks of outage today i finally able to use a bit and then disconect again. Getting error In router page "could not bring up link"
Any help? ?
Any help? ?
Message 1 of 4
(932 Views)
3 REPLIES 3
Re: plusnet is worst internet provider in town
21-04-2013 7:22 PM
Digital Care team will be back Monday.
They'll pick this up and deal with it!
Geoff,
York.
York.
Message 2 of 4
(392 Views)
22-04-2013 2:05 PM
Sorry to hear that you've had a fault, I've had a look over your connection and it's showing that you're currently connected, is that the case for you?
Chris
Chris
Message 3 of 4
(392 Views)
22-04-2013 2:13 PM
Can you hear/have you heard any crackling or other noises on the line when using the phone? Have you had any problems with incoming or outgoing calls? These things indicate line faults that will affect your broadband.
Message 4 of 4
(392 Views)
