output power at 0.0
- output power at 0.0
output power at 0.0
04-01-2013 6:36 PM
Hi to all...
Today I noticed that the line has changed(21CN upgrade).
Upload is 0.9 (which is great) but download has remained at 6.8.I know there's a 10 day training period.Output power (down) is 0.0...is this normal?
DSL Connection
Link Information
Uptime: 0 days, 1:38:39
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,179 / 24,382
Data Transferred (Sent/Received) [MB/MB]: 13.48 / 85.71
Output Power (Up/Down) [dBm]: 10.9 / 0.0
Line Attenuation (Up/Down) [dB]: 2.1 / 5.0
SN Margin (Up/Down) [dB]: 7.1 / 8.5
Loss of Link (Remote): -
Error Seconds (Local/Remote): 36 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 62
HEC Errors (Up/Down): 0 / 192
DSL Connection
Link Information
Message 1 of 5
(926 Views)
4 REPLIES 4
Re: output power at 0.0
04-01-2013 6:42 PM
For Downloads it is not possible for your router to send power to the exchange.
So it must be zero.
So it must be zero.
Bandwidth (Up/Down) [kbps/kbps]: 1,179 / 24,382is the vital figure.
Message 2 of 5
(486 Views)
04-01-2013 6:48 PM
To address the point properly
Output power - zero is just your router not reporting it
Speeds - I assume from speed test is probably being limited by the Current Line Speed here https://portal.plus.net/my.html?action=data_transfer_speed
It should pick up soon - if it doesn't I am sure that it will be picked up here tomorrow
Message 3 of 5
(486 Views)
04-01-2013 7:20 PM
thanks...it's waiting time now.
As for the output being 0.0,I just asked because it wasn't like that before the upgrade.
Message 4 of 5
(486 Views)
07-01-2013 5:04 PM
Hi there, apologies for the delayed reply - speeds should have improved now, please let us know if not?
Message 5 of 5
(486 Views)
