is there a software to monitor the modem connectivity?
- is there a software to monitor the modem connectiv...
06-09-2010 2:50 PM
Hi all
I have Linksys WGA354A
I want to ask if there is a software i can use to check the history or a log of the router;s connection, how long, when it was connect and disconnect and got re-connect again etc..
I suffered from a bad disconnection a couple of months back and I changed the microfilter and router and ti was stable, but the connection speed was dwon from like 2600kbps to 1600k so I switched back to the old router but still got the new filter.
The connection i feel is better than months ago but still not as good as when I had the new router.
I am not too techy so please bear with me and I always suffer from like a "blindspot" when when browsing is usually smooth then after a while it will take forever in one page and it will then go smooth after. I guess this is when the router drops the connections and got reconnected.
J
J
Message 1 of 2
(710 Views)
1 REPLY 1
Re: is there a software to monitor the modem connectivity?
06-09-2010 4:08 PM
This is basic but might help, http://www.connectionmonitor.net/
We do keep logs ourselves but can only really provide these on an ad hoc basis so I hope this helps:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image128378555919.png" />
Message 2 of 2
(412 Views)
