engineer been, dlm reset completed but...
- engineer been, dlm reset completed but...
18-09-2014 1:42 PM
ip profile now showing at 48mb but im still unable to exceed 31.8mb on any speed test from and computer in my house, all wired tests, no wireless used in testing, possible faulty router maybe?
Message 1 of 4
(584 Views)
3 REPLIES 3
Re: engineer been, dlm reset completed but...
18-09-2014 1:54 PM
https://portal.plus.net/my.html?action=data_transfer_speed probably that is wrong and it doesn't match BT's IP profile
FTTP 500 regrade from Tues 28th November
Message 2 of 4
(331 Views)
18-09-2014 2:00 PM
I've updated the profile so if you reboot the router you should see the increase.
Message 3 of 4
(331 Views)
18-09-2014 2:06 PM
Thank you kindly
Message 4 of 4
(331 Views)
