download speed cut by two thirds
- download speed cut by two thirds
22-02-2013 11:15 PM
I just checked my download speed on this: http://www.mybroadbandspeed.co.uk/ and it's been consistently around 6783 kbps but tonight it's dropped to 2632 kbps.
Is that just because it's friday night or something?
Message 1 of 4
(1,077 Views)
3 REPLIES 3
Re: download speed cut by two thirds
23-02-2013 7:59 AM
Impossible to say with so little to go on. What is your router sync rate?
Message 2 of 4
(563 Views)
23-02-2013 8:10 AM
Also as the message says, it may not be accurate. What does speedtest.net give?
Quote Sorry - My Broadband Speed is currently experiencing technical difficulty and may display misleading test results. Thanks for bearing with us while we fix things.
Message 3 of 4
(562 Views)
25-02-2013 1:42 PM
Can't see anything on your account or line that would explain that, have speeds returned since or are you still suffering with a slow connection?
Message 4 of 4
(562 Views)
