awful pings just get worse
- awful pings just get worse
21-05-2010 2:36 PM
thats it. i have had enough ping is unexceptable
Pinging bbc.co.uk [212.58.224.138] with 32 bytes of data:
Reply from 212.58.224.138: bytes=32 time=25ms TTL=121
Reply from 212.58.224.138: bytes=32 time=41ms TTL=121
Reply from 212.58.224.138: bytes=32 time=28ms TTL=121
Reply from 212.58.224.138: bytes=32 time=36ms TTL=121
Reply from 212.58.224.138: bytes=32 time=51ms TTL=121
Reply from 212.58.224.138: bytes=32 time=40ms TTL=121
Reply from 212.58.224.138: bytes=32 time=62ms TTL=121
Reply from 212.58.224.138: bytes=32 time=195ms TTL=121
Reply from 212.58.224.138: bytes=32 time=211ms TTL=121
Reply from 212.58.224.138: bytes=32 time=80ms TTL=121
Reply from 212.58.224.138: bytes=32 time=87ms TTL=121
Reply from 212.58.224.138: bytes=32 time=74ms TTL=121
Reply from 212.58.224.138: bytes=32 time=95ms TTL=121
Reply from 212.58.224.138: bytes=32 time=78ms TTL=121
Reply from 212.58.224.138: bytes=32 time=60ms TTL=121
Reply from 212.58.224.138: bytes=32 time=50ms TTL=121
Reply from 212.58.224.138: bytes=32 time=54ms TTL=121
Reply from 212.58.224.138: bytes=32 time=77ms TTL=121
Packets: Sent = 22, Received = 22, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 25ms, Maximum = 211ms, Average = 68ms
getting my mac code i am out of here.
Message 1 of 3
(690 Views)
2 REPLIES 2
Re: awful pings just get worse
21-05-2010 9:14 PM
replyed to your other thread, it may be off improtant for your next choice of isp. As if its exchange congestion you need to go to the likes of llu providers
Message 2 of 3
(340 Views)
21-05-2010 9:21 PM
mod:note
I've locked this thread in favour of http://community.plus.net/forum/index.php/topic,85919.0.html
Message 3 of 3
(340 Views)
