Wired speed issues with fibre optic broadband
- Wired speed issues with fibre optic broadband
08-01-2013 9:48 AM
I have just switched to Plusnet fibre optic broadband having had 1Mbps speed from Orange on a non fibre Optic broadband service. I was promised a speed of up to 30Mbps with the Plusnet fibre optic service.
I have had the speed checked at the main BT socket and am getting 40Mbps and again the same speed at the modem( The BT engineer laid a wire from the Main socket upstairs to the modem).
When I connect any other computer wirelessly I can get speeds of at least 20Mbps which I am happy with but the speed drops with the wired connection to my desk top computer to barely more than 5 Mbps.
I have swapped over the Cat 5 cable with another and swapped them around to see if it is one of the cables that is faulty but the speeds are still 5Mbps . How do I know it is not a faulty socket at the back of the router or modem? I have tried all 3 of the yellow out sockets on my router but it made no difference.
I think it may be some software that I have on my Dell computer but the helpdesk would not even help me to see if it was the computer or not,even to suggest something .
Please help!
Please help!
Message 1 of 5
(961 Views)
4 REPLIES 4
Re: Wired speed issues with fibre optic broadband
08-01-2013 9:58 AM
A few questions
Which model Dell computer
Which operating system
How are you checking the speeds
Can you try using this check http://www.thinkbroadband.com/download/
One other thing worth doing is to install NetworX http://www.softperfect.com/products/networx/ which gives an immediate readout of the actual speeds
Message 2 of 5
(465 Views)
08-01-2013 10:00 AM
You've proved that the modem supports 20Mbps with your wireless test. What you can do is connect your computer directly to the modem using these instructions: http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
If that gives a slow speed it's not a problem with the router but with your PC.
Message 3 of 5
(465 Views)
08-01-2013 10:27 AM
Thanks for your help,I have cut out the router and done a spped test direct from the modem to my computer and it is also showing the reduced speed of 5 Mbps. The problem must be with some software on my computer ,I have replaced my current anti virus software with McAfee ,could there be something else choking the download speed?
Message 4 of 5
(465 Views)
08-01-2013 10:37 AM
First thing to try would be with the anti-virus disabled.
Are you using Windows and if so which version?
Message 5 of 5
(465 Views)
