Will my speeds change
- Will my speeds change
21-04-2009 1:51 AM
Hi, Im on op3 package at the mo and want to go over to the unlimted package. My question is will i notice any change with the speeds? i have looked at the expected speeds you show on unlimted but i dont know what speeds im capped on with op 3. Im not expecting faster speeds,just the same with the extra banwidth. The reason i would like to know this is i play a lot of onlines games and use p2p. Thanks
Message 1 of 6
(1,290 Views)
5 REPLIES 5
Re: Will my speeds change
21-04-2009 9:09 AM
You will see some speed differences, have a look here for restrictions http://www.kitz.co.uk/isp/plusnet_shaping2.htm - you can compare the 2 packages side by side.
The gaming is Titanium on both, but restricted to 2mbps on unlimited - though this shouldn't be an issue.
P2P is the same between midnight and midday, after that unlimited is throttled more.
Message 2 of 6
(474 Views)
22-04-2009 3:51 AM
Thank you for the quick reply
Message 3 of 6
(474 Views)
22-04-2009 4:40 AM
i moved from option 3 to unlimited and its much the same. apart from not having my bandwidth monitor open 24/7
pn legacy product info is here http://www.plus.net/support/broadband/products/archive/index.shtml but adiewoo pointed you to the best compare site
Message 4 of 6
(474 Views)
23-04-2009 9:41 AM
Been on unlimited for nearly 2 months and with 3 teenagers on xbox etc and playing online the only difference i have noticed is that i dont have to keep checking how much it is going to cost me at end of month , very happy with it
Message 5 of 6
(474 Views)
23-04-2009 10:29 AM
Hi Wacky17,
If you do decide to change you can do so by following this link: http://portal.plus.net/upgrade_process.html?memberheader=upgrade
If there's any issues just give one of us on here a heads up and we'll see what we can do for you. As posted though I don't think you will do Thanks all.
Message 6 of 6
(474 Views)
