Why is my IP Profile Stuck??
- Why is my IP Profile Stuck??
25-05-2011 11:08 PM
I have experienced a cap on my download speed for the last month at 2000Kbps. These are the results i keep getting from the BT speedtest:
Download speedachieved during the test was - 1834 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
BT wholesales line test show the following results:
Upstream Link Info
Loop Loss Loop Loss Add Text SNR Margin Errored Seconds HecErrors Cell Count Speed
13.5 23 0 0 35247122 448
Downstream Link Info
Loop Loss Loop Loss Add Text SNR Margin ErroredSeconds HecErrors CellCount Speed
24.5 11 0 0 327468916 8128
DSL Max Data
BIP Interface Data
Current line rate Line rate change timestamp Maximum Stable Rate Recalcuated Profile Timestamp Maximum Stable Rate
7150 2009-06-18T00:15:00 N 2009-07-29T18:32:00 8128
My profile at Plusnets end mirrors this information and they have my speed set at 7150Kbps as per the delta report they have recieved from BT. My problem seems to be an IP Profile at the exchange that is stuck at 2000Kbps. I have had this problem a few years ago and someone at PLusnet who understood the problem had my IP Profile at the exchange reset, but i seem to be struggling this time with this problem. I have raised tickets 42856849 and 42895628 but dont seem to be getting anywhere. Who can i contact who may understand this problem?
Upstream Link Info
DSL Max Data
BIP Interface Data
Message 1 of 6
(9,084 Views)
5 REPLIES 5
Re: Why is my IP Profile Stuck??
25-05-2011 11:19 PM
Hopefully JoJo will pick this up tomorrow, and go request some changes at BT's end.
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Message 2 of 6
(622 Views)
26-05-2011 10:19 AM
Hi newbec,
I'll look into that now for.
Jojo
Jojo
Message 3 of 6
(622 Views)
26-05-2011 6:00 PM
Thankyou Jojo
Neil
Neil
Message 4 of 6
(622 Views)
27-05-2011 4:43 PM
Glad it's ok, I did sort but by the time It'd gone through I forgot to tell you
Message 5 of 6
(622 Views)
27-05-2011 11:16 PM
Thanks again. Normal service has been resumed
Date of Speed Test: 2011-05-27 23:13:45
Download Speed: 6868 kbps (858.5 KB/sec transfer rate)
Upload Speed: 381 kbps (47.6 KB/sec transfer rate)
Message 6 of 6
(622 Views)
