Which is right?
- Which is right?
Which is right?
16-02-2012 6:35 PM
looking at PN my line speed says 5MB however BT Speedtester says :
IP Profile for your line is - 4.5 Mbps
Shouldnt they be the same?
Re: Which is right?
16-02-2012 6:41 PM
Plusnet have control over their profile but not the BT one.
Re: Which is right?
16-02-2012 7:05 PM
When I run download speed tests the best i'm getting is 4.3MB with an upload of 330 so the results dont match either profile? My router is in master/test socket and I'm contected via cable.
I would of thought if my router was showing a connection sync speed of 5728 I shou;ld be getting closer to the 5MB download speed not 4.3MB
Re: Which is right?
16-02-2012 7:19 PM
An actual speed of 4.3Mbps is about right for your current 4.5Mbps IP Profile.
jim:green inadvertent hitting quote instead of edit fixed mod:end
Re: Which is right?
16-02-2012 7:33 PM
Re: Which is right?
17-02-2012 9:34 AM
Your current sync is 5664Kbps, in order to get a profile of 5000Kbps you'd need to sync at over 5696Kbps.
Jojo
Re: Which is right?
17-02-2012 4:13 PM
I'll check my BT IP in a few days to see if they have increased it to 5MB
Ive been on Samknows exchange checker and it says 21CN is due to be completed 31/3/12 so fingers crossed this will give me a few more MB's. Will I need to do anything on the 31/03/12 to switch over?
Re: Which is right?
17-02-2012 5:03 PM
Re: Which is right?
17-02-2012 5:45 PM
Do i need to do anything when my exchange gets 21cn next month
Re: Which is right?
17-02-2012 5:52 PM
