Which Speed Tester should I believe?
- Which Speed Tester should I believe?
21-03-2012 9:45 AM
After a mystery router restart this morning, I thought I'd do some speed tests. The results were:
Down / Up
BT 2970 / 368
Think Broadband 3209 / 379
My Broadband Speed 3555 / 384
Which result should I believe?
Down / Up
BT 2970 / 368
Message 1 of 6
(1,559 Views)
5 REPLIES 5
Re: Which Speed Tester should I believe?
21-03-2012 10:00 AM
You can run a number of speed tests over a relatively short time period using the same site and get variations so none are 'guaranteed accurate'.
It would depend on a number of factors at the time of each test.
This is a lovely piece of speed test software http://www.gmwsoftware.co.uk/ showing the variation over time of my connection below.
Message 2 of 6
(590 Views)
21-03-2012 4:30 PM
Strat - I agree about that piece of software - I've been using it for a few days now and it looks very promising
Mfiles
Mfiles
Message 3 of 6
(590 Views)
22-03-2012 9:39 AM
Message 4 of 6
(590 Views)
22-03-2012 11:45 AM
Lower but more consistent than mine which illustrates a persistent drop in D/L speed at around 8:30 every night
Message 5 of 6
(590 Views)
22-03-2012 4:08 PM
It does present things in a way which highlights issues/odd-balls - My Ping stays steady at about 32ms until 5pm and then goes up - This is not a problem for me but as I say, it highlights things without having to go digging for things.
You can leave it running without any intervention.... I'll see if I feel the same in a month's time
Message 6 of 6
(590 Views)
