What happens next ?
- What happens next ?
- « Previous
- 1
- 2
- Next »
Re: What happens next ?
18-01-2012 6:34 PM
Thanks Matt ! It helps a lot
Message 16 of 20
(284 Views)
30-01-2012 4:08 PM
Hi Jojo/Matt
Can you have a fixed line profile of 6db - INP1 ?
I'm on 21cn but on a 992.1 setting.
Thanks choo
Thanks choo
Message 17 of 20
(284 Views)
31-01-2012 1:04 PM
@choo
Unfortunately ADSL1 interleave (via 21cn) works exactly like 20cn. I.E. one level that affects both upstream and downstream equally. Your Attenuation means that you're on the cusp of benefiting from being on ADSL2+ but I wouldn't like to necessarily recommend in case it made things worse, but that's the only way we could define interleaving.
Jojo
Jojo
Message 18 of 20
(284 Views)
31-01-2012 1:07 PM
I am on 21CN ADSL1 (moved from 20CN) and the interleave depths are 32 down 4 up which appears to be about the mid setting
Message 19 of 20
(284 Views)
31-01-2012 7:11 PM
Quote from: Joanne @choo
Gesundheit!
Message 20 of 20
(284 Views)
- « Previous
- 1
- 2
- Next »
