We only get stable internet when plugged direct into test socket
- We only get stable internet when plugged direct in...
- « Previous
- 1
- 2
- Next »
Re: We only get stable internet when plugged direct into test socket
12-01-2013 4:06 PM
You haven't commented about your Extension sockets and whether they are all Secondary types.
As you have been having a number of losses of sync, from now on you will be better disconnecting in the following manner when you want to unplug the modem/router or filter, front plate etc from the line -
Login to the modem/router (as you would for stats) see here and either click on Broadband Connection on the LH menu where you will see what is shown in section 5 (and how to get stats), and in the lower Internet box click "Disconnect" or do that from the first screen.
Then pause before powering down the modem/router. Wait a minute before unplugging things from the line.
This procedure will help to prevent the Exchange Dynamic Line Management (DLM) from thinking you have a (worse) dropping connection. Which will ultimately result in a raised Target Noise Margin and/or on 21CN Banded speed, both of which give you lower speed than your line should achieve.
Take at least 10 minutes changing whatever, in this case Filters, before reconnecting and powering up again. I recommend doing this no more than 5 times in an hour and leave for the rest of the day thereafter. After powering up, login to the modem/router and click "Connect" if it hasn't automatically.
In view of what has already happened. it would be a good idea if you did a copy and paste of your current modem/router stats (don't forget to click "View more.." first, and then post the new stats taken immediately after power up after the filers have been changed.
Quote from: ReedRichards ................ and no telephone is connected then the quality of the filter is immaterial.
I'm sorry RR that is not right, the quality of the filter is of material importance even when a phone is not connected but becomes more so when a phone is connected.
12-01-2013 4:52 PM
12-01-2013 5:10 PM
Quote from: Anotherone Don't bother to post a picture of that Block filter that looks like a socket splitter
I didn't ask for a picture of the filter in the master socket that we've already seen, I asked for a picture of the filter being used to plug the telephone in to the extension socket (we know it's in an extension because it stops working when the test socket is used). I requested that for two reasons: to confirm one is actually installed (unless I've missed it we haven't determined that) and to see if that is also a duff block filter).
I'd also stress the importance of the tests of incoming and outgoing calls. It is apparently stable when in the test socket and in the master when the bell wire has been snipped but that could just be a co-incidence if the phone hasn't been used.
12-01-2013 5:31 PM
Quote from: Oldjim The obvious and unhelpful answer is either your internal wiring or you have something plugged in without a filter
The "or" we could actually make an "and/or"
12-01-2013 5:42 PM
12-01-2013 8:21 PM
I don't think the micro filter is the problem because the one used is the first one I could find and we have previously used the rats tail filter and issues still occurred.
Many thanks
12-01-2013 8:32 PM
12-01-2013 8:43 PM
Cheers
12-01-2013 9:40 PM
You keep saying 'the filter'. If you have the router plugged in to one socket and the telephone in to another you MUST use two filters (one for each) otherwise problems are guaranteed.
12-01-2013 11:18 PM
This is going off topic (for which I apologise) but I would be really interested if you can explain how that can possibly be true.
12-01-2013 11:26 PM
14-01-2013 9:18 AM
Sorry for the lack of updates..
I just wanted to test your basic suggestions first.
We have:
1: Removed bell cable
2: Re-wired white and blue cables.
So far seems stable (1 day uptime+).
Could someone advise what is so called the 'average' uptime is?
14-01-2013 9:40 AM
Some connections are of course shorter and/or better than others which are of necessity obliged to run closer to the "ragged edge" of reliability, which leads to the very grey area of what constitutes a fault.
I would personally be asking questions (starting with checking my home set up) about a connection which dropped more than once a week, but my guess is there is no "ball park" uptime figure.
14-01-2013 9:56 AM
- « Previous
- 1
- 2
- Next »
