Very slow speeds
- Very slow speeds
Very slow speeds
07-01-2014 1:30 PM
Hi I hope someone can help.
I had a problem with my BT phone line just before Christmas due to the storms, the line became unusable, very crackly, and it took until last Friday 3rd January for BT to fix it. During the eleven days the line was unusable my internet connection from Plusnet was obviously unusable as well. Since the BT line was fixed the internet has started working again but the speeds on it are terrible. I have tried rebooting the router, changing the filter etc but it's not helping. I don't have a test socket to try.
BT Wholesale Availability Checker: ADSL2+ downstream line rate up to 13.5 Mbps
My router (TP-LINK TD-W8961ND) stats are currently :
SNR margin: downstream 36.6 db upstream 26.2 db
Line attenuation: downstream 23.0 db upstream 11.4 db
Data rate: downstream 286 kbps upstream 446 kbps
BT Wholesale Broadband Performance Test
Ping Latency (ms): 78.13
Best Effort Test
Download speed achieved during the test was - 0.2 Mbps
For your connection, the acceptable range of speeds is 0.1 Mbps-0.25 Mbps.
IP Profile for your line is - 0.25 Mbps
Upstream Test
Upload speed achieved during the test was - 0.27 Mbps
Upstream Rate IP profile on your line is - 0.83 Mbps
I did the BT Wholesale Broadband Performance Test three times yesterday at 2pm, 8pm and midnight, to see if the time of day made any difference but it was virtually the same each time.
https://portal.plus.net/my.html?action=data_transfer_speed shows the following:
Estimated line speed: There's no speed estimate currently held on your account.
Current line speed: 0.2 Mb
It's been four days since BT fixed the line problem and there is no sign of the speed increasing so will it increase by itself after ten days of having a stable line again? Or is this something that has to be manually reset by Plusnet / BT ?
Thanks for your help.
Best Effort Test
Upstream Test
Message 1 of 4
(1,653 Views)
3 REPLIES 3
Re: Very slow speeds
07-01-2014 2:23 PM
Message 2 of 4
(443 Views)
08-01-2014 12:19 PM
Thanks for your help but unfortunately the speed is still very slow, here are the stats from just now:
Router:
SNR margin: downstream 6.1 db upstream 27.3 db
Data rate: downstream 15603 kbps upstream 448 kbps
Ping Latency (ms): 62.50
Best Effort Test
Download speed achieved during the test was - 0.19 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is – 13.76 Mbps
Upstream Test
Upload speed achieved during the test was - 0.36 Mbps
How can I get the speed back to normal? I usually get between 12 to 14 Mbps download and 0.9 Mbps upload.
Router:
Best Effort Test
Upstream Test
Message 3 of 4
(443 Views)
08-01-2014 1:13 PM
Message 4 of 4
(443 Views)
