Very Slow Internet Speed
saidalinneagoe
Unlimited Fibre Extra
Telephone:
<Redacted>
I got speeds over 50 Mbps now I get under 10 Mbps this is the worst internet I have seen.
Moderator's note:
All caps title/text edited as per Forum rules. All caps title changed as per Forum rules. Post released from automatic spam filter. Personal information removed but still visible to Plusnet staff.
19 REPLIES 19
Legend
Fixes: 259
Re: VERY SLOW INTERNET SPEED !!!!
@saidalinneagoe
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
saidalinneagoe
Screenshot_5-4-2024_04624_speedtest.btwholesale.com.jpegScreenshot_5-4-2024_03958_192.168.1.254.jpegScreenshot_5-4-2024_04430_192.168.1.254.jpeg
Fixes: 420
@saidalinneagoe
Report a fault:
Report your problem by text message
Our text service is available 24 hours every day.
Text HELP for broadband or Text PHONE for home phone to 07800008121 (charges may apply at your standard rate)
  • We’ll run tests on your connection to find out what’s going on
  • If you need an engineer, we’ll text you in 15 mins to book a slot
  • If no engineer’s needed, our UK based support team will call you within 30 mins to help sort the problem
  • Call backs available Mon-Sun: 8am to 7.30pm
saidalinneagoe
I don t have a corded phone I did all possible tests. I believe the issue is somewhere on the line I tried even a different  adsl moodem.
Legend
Fixes: 259
@saidalinneagoe  The data in the first of your Hubs Technical log shots is incomplete - what are your noise margins, please? Or you could just use the links provided by @Baldrick1 , which would save me bothering to try and help.
@saidalinneagoe wrote:
@saidalinneagoe
Can you re-do the above screenshot in such a way that the Plusnet banner doesn't obscure the info @jab1 needs.
You don't need to capture the entire page, just the section from "DSL uptime:" down to "Data sent / received:"
saidalinneagoe
MatthewWheeler
Fixes: 480
Hi @saidalinneagoe
I can see you have a fault open with us at present and we need to arrange for a Openreach visit to your property.
Can you respond to the ticket on your account so we can get this organised
 Matthew Wheeler
Legend
Fixes: 259
@saidalinneagoe Thanks for full information - makes life much easier. From the above, it appears you have a DSL drop around two days ago? What is the 'uptime' showing on your 'broadband - internet' tab please? and can you export your event log and attach it to a post,. Your noise margin looks OK, but your data rate figures tell a story - something has caused DLM to throttle your connection to achieve stability.
Your data transfer figures look very high, but I don't know when they get reset.
Sight of the Event Log may prove interesting.
Aspiring Hero
Fixes: 80
@jab1
I think you mean the >Home >Status.
Network uptime: this will details how long the broadband user has been logged in
System uptime: this will details how long the Hub has been powered on
However if you look at post 3, that information has already been provided.
The data usage resets to zero on DSL, PPPoE connection or reboot
HTH
Edit: on checking again I see post 3 shows 6 hour uptime, the last post shows  just under 2 days
Legend
Fixes: 259
Thanks @Dan_the_Van I have problems getting my head round the H2, having never used one in anger, but post #3 and post #8 don't seem to compute?
Aspiring Hero
Fixes: 80
@jab1
Problem is the post 3 is missing important data, also depends when it was taken. maybe 36 hours ago 🤔
The event logs will reveal when the Hub last started
Have a good evening, I'm done for the day.
Legend
Fixes: 259
Exactly, @Dan_the_Van . Same to you, and I think I'll bring my 'posting holiday' forward by 5 days - I need a break! 😀
saidalinneagoe
