VPN Problems
- VPN Problems
VPN Problems
27-09-2007 10:30 AM
My wife works from home and needs to VPN into her company's network (which is in the USA). However, the VPN continually drops (9-10 times an hour).
She's been on the phone to her colleagues who are connecting via other ISPs and they haven't had any issues.
This is the only problem - the connection to "the internet" is otherwise OK.
I realise that this is probably outwith PN's control as it may be outwith their network but just wondered if anyone else was having problems or if there were known issues.
I'm not at home just now so can't do any tracerts etc.
Re: VPN Problems
27-09-2007 10:32 AM
There's been no known issues that we're aware of.
Might be an idea to suggest trying to reboot the router and see if this leads to an improvement in service.
Re: VPN Problems
27-09-2007 10:38 AM
She's going to try to get in touch with the IT folks at the US office to see if there's something up at their end but they're not in till 2pm our time. The office in Scotland doesn't have any local IT support and, as her PC is owned by her work, I'm not allowed to check anything without the go-ahead from their IT dept.!
Re: VPN Problems
27-09-2007 11:32 AM
That's using the Cisco VPN client
Re: VPN Problems
27-09-2007 11:44 AM
That's what I was hoping - just trying to rule out the ISP and/or routing problems.
A reboot of the router and PC seems to have done the trick for now.
Re: VPN Problems
27-09-2007 4:06 PM
Are you using a software VPN or does the ISDN Router play a part?
Re: VPN Problems
27-09-2007 4:27 PM
Quote from: DocBambs - a fixed IP address makes a huge difference.
Never heard of a broken IP address before...what did you fix it with?
SORRY......Couldn't resist it.....beg forgiveness
Re: VPN Problems
27-09-2007 4:38 PM
By the way, I'd guessed the Scottish connection before you mentioned it. It was use of the wonderful word "outwith" to mean "outside". I've only ever heard it used by Scots friends before.
Re: VPN Problems
27-09-2007 4:43 PM
Quote from: Dick
Granted (with pleasure!)
Re: VPN Problems
27-09-2007 6:44 PM
The VPN has been stable since the reboot.
Her IT department will keep an eye on things though.
@hulls:
Well spotted with the Scottish connection!!
Re: VPN Problems
27-09-2007 9:23 PM
Plusnet Technology
Re: VPN Problems
27-09-2007 11:27 PM
