Usage Cap
- Usage Cap
Usage Cap
18-10-2011 4:51 PM
Had my Fibre connection activated yesterday evening and so far so good - amazing speeds - currently I'm almost connected at max rate 37Mb out of 40Mb
When I ordered the package, the sales adviser said that I could cap my usage so that I couldn't go over the 40GB limit. I've always been on 'unlimited' packages before but ADSL wasn't working for me and 'unlimited' fibre packages are currently expensive. Due to me not knowing how much I've been using in the past I'd like to be able to manually cap my service so I can keep tabs on this. Where can I find this section?
Many thanks
Many thanks
Message 1 of 6
(879 Views)
5 REPLIES 5
Re: Usage Cap
18-10-2011 4:57 PM
https://portal.plus.net/data_transfer_watch/
It doesn't cap your usage just the amount you pay - although moving from fibre to speed restricted you will think it is capped
Message 2 of 6
(502 Views)
Re: Usage Cap
18-10-2011 5:01 PM
Ok so going to that page, what would I need to set it at so that I don't go over my 40GB?
I could just let it run over if I wanted to but I don't wanna be met with a high first bill so I wanna see when it stops in the month, if it does, when I hit 40GB.
Message 3 of 6
(502 Views)
Re: Usage Cap
18-10-2011 5:01 PM
Zero
Message 4 of 6
(502 Views)
Re: Usage Cap
18-10-2011 5:03 PM
Nice one
Message 5 of 6
(502 Views)
Re: Usage Cap
18-10-2011 5:31 PM
You can also check your usage day-to-day here
Message 6 of 6
(502 Views)
