Upload uncap, Big Mistake
- Upload uncap, Big Mistake
19-03-2012 4:00 PM
Well that did not work out very good,
the errors on the line increased tremendously and my download SNR has gone up to 12dB,
has been stable at 6dB since i joined 3 months ago with a corresponding drop of sync by 2.5meg which now makes BBC/Iplayer buffer.
Could you check my line for any faults,
and if nothing found reinstate the upload cap please.
I may have to come back to you and ask for a SNR reset if the SNR does not come down to its previous level. ;(
Mike
Re: Upload uncap, Big Mistake
19-03-2012 4:41 PM
Can you tell me if you're using any extension cables/sockets? Do you have a test socket you can plug into?
Jojo
19-03-2012 5:36 PM
Quote from: Joanne Hi Mike,
Hi JoJo
I have a filtered faceplate, and cat5 from that to the router.
i could fit the router to the test socket and run the cat5 to a single PC, but from the tests i did when first installing it, no difference at all.
I do have a long overhead line which is i think is the real problem.
pS it's dropping out like Mad today
PPS. just to satisfy my own curiosity as well, i will connect the router to the test socket tomorrow morning.
Mike
20-03-2012 9:21 AM
Let me know when it's in the test socket so I can take a look at how the line is performing. If it is the overhead line and we see performance issues while it's in the test socket, we can look at getting an engineer out if necessary.
Jojo
20-03-2012 10:19 AM
Well im in the test socket now.
but my SNR has gone up to 13.5dB and i have been dropped to ADSL2
have also included noise graph from the week before the line was uncaped
pity life does not have a restore point
20-03-2012 11:46 AM
Shall we see how it goes over the next couple of hours and then reset the SNR?
Jojo
20-03-2012 12:57 PM
Quote from: Joanne Shall we see how it goes over the next couple of hours and then reset the SNR?
Hi JoJo
If you cant identify any fault with the line,
i think the best thing would be to reinstall the upload cap
a loss of 600k upload i can put up with, a drop of 2Mb download is a pain when you are at the lower end of speed capability’s.
once that has taken effect could you please reset the SNR,
i just hope the DSLAM does not have a memory of past problems and i can get back to ADSL2+ and a 6700 sync where i was last week.
Thanks for your help
Mike
20-03-2012 2:11 PM
I'll cap the upstream and see how that goes. Let us know tomorrow once the order completes.
Jojo
21-03-2012 2:41 PM
I'll cap the upstream . Let us know tomorrow once the order completes.
JoJo
the upload cap has now been applied could you now reset the SNR please
I know this will mean another 10 day training peroid, but hopefully the SNR
will go back to what it was before i thought that uncaping the upload was worth a try.
Mike
21-03-2012 5:24 PM
Just requested the SNR reset for you, should take effect soon. I hope that in combination with the capped upstream will sort things for you.
21-03-2012 10:54 PM
Quote from: Matt Just requested the SNR reset for you, should take effect soon. I hope that in combination with the capped upstream will sort things for you.
reset happened at 17:34, so far so good, back to 6dB snr down and G.992.5 annex A
Thanks for all your help,
Mike
22-03-2012 11:54 AM
22-03-2012 4:27 PM
Quote from: _Adam_Walker_ PS is that a Matchless you're sat on in your avatar? I'm a fan of vintage bikes, I've got fond memories of my grandad's Brough Superior
Yes it is well done, taken some 45 years ago
I still have a collection of old bikes 1929 Ariel- 1969 Triumph- 1953 Bsa- and a younger 1963 Matchless.
but my Bsa-not-runs.... as yet.
Mike
22-03-2012 4:54 PM
22-03-2012 11:29 PM
Quote Bsa-not-runs
I've got a thing about Norton Commando's would love own an older one...
go for it, you only get the one chance in this life.
back to this internet thing..
interleaving, auto, on or off i cant tell which is applied to my line now
no FEC errors but a few CRC up errors and low ping
****@mike-desktop:~$ ping google.com -c 4
PING google.com (74.125.230.133) 56(84) bytes of data.
64 bytes from lhr14s02-in-f5.1e100.net (74.125.230.133): icmp_seq=1 ttl=55 time=12.1 ms
64 bytes from lhr14s02-in-f5.1e100.net (74.125.230.133): icmp_seq=2 ttl=55 time=10.7 ms
64 bytes from lhr14s02-in-f5.1e100.net (74.125.230.133): icmp_seq=3 ttl=55 time=10.4 ms
64 bytes from lhr14s02-in-f5.1e100.net (74.125.230.133): icmp_seq=4 ttl=55 time=10.2 ms
--- google.com ping statistics ---
4 packets transmitted, 4 received, 0% packet loss,
rtt min/avg/max/mdev = 10.214/10.884/12.153/0.758 ms
