Upload speed
- Upload speed
Upload speed
13-04-2013 7:37 AM
PTN AG04 did several test,s but still the same ?
this my normal
http://speedtest.net/result/2629794985.png
Re: Upload speed
13-04-2013 7:43 AM
Re: Upload speed
14-04-2013 7:12 PM
Re: Upload speed
15-04-2013 1:33 PM
Re: Upload speed
15-04-2013 2:31 PM
have just done another BTW test Ping is now sky high still barely a DL speed
its playing Havoc with my gaming
Re: Upload speed
15-04-2013 4:06 PM
Re: Upload speed
15-04-2013 4:33 PM
i did my Netgear router earlier with no effect.
Am on ptw-ag01. now
Re: Upload speed
16-04-2013 9:35 AM
How's your upload speeds today?
Re: Upload speed
16-04-2013 11:02 AM
is it possible i have a glitch with my BT modem ?
Re: Upload speed
16-04-2013 1:27 PM
Re: Upload speed
16-04-2013 1:37 PM
Re: Upload speed
16-04-2013 1:39 PM
well at least thats what Netgear tells me
Re: Upload speed
16-04-2013 1:44 PM
I noticed the last 2 Network status reports, this being the last made no mention of the Gateway mentioned in the initial report. So did that problem turn out to be more widespread which may account for some of the oddities seen. Nor did the Network usage graphs seem to indicate any significant gateway hopping from that gateway - for what they are worth in their present state
Re: Upload speed
16-04-2013 1:47 PM
If you follow the link, that's for a direct PPPoE dialler connection by-passing the router. But if you aren't seeing problems now, probably not worth the effort.
Re: Upload speed
16-04-2013 2:01 PM
as it totally messing my gaming
