Unreliable connection
- Unreliable connection
31-08-2011 3:03 PM
DSL Connection
Link Information
Uptime: 0 days, 0:06:03
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,664
Output Power (Up/Down) [dBm]: 11.5 / 16.0
Line Attenuation (Up/Down) [dB]: 31.5 / 63.5
SN Margin (Up/Down) [dB]: 9.0 / 6.5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 8 / 413
CRC Errors (Up/Down): 8 / 1
HEC Errors (Up/Down): 1 / 1
Re: Unreliable connection
31-08-2011 3:06 PM
Phone exchange:
BURROWBRIDGE
Estimated line speed:
1.0Mb (Accurate to within +/- 1Mbit) - Checked on 2011-01-30 14:50:18
Current line speed:
0.5 Mb
31-08-2011 3:23 PM
I've tested your line and it looks like your line profile is set to 6dB SNR margin which is a little low considering the high loop loss. This low SNR margin is likely causing the drop outs and the variable speeds. I have initiated an SNR reset which will retrain your line over the next ten days in order to re-stabilise your line. Please monitor your connection and let us know if the problems continue. Bear in mind initially you will likely see some drop outs and fluctuations in your speed during the training period.
01-09-2011 8:15 PM
01-09-2011 8:32 PM
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
638 Kbps
0 Kbps 1000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 638 Kbps
For your connection, the acceptable range of speeds is 200-1000 Kbps.
Additional Information:
Your DSL Connection Rate :960 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 750 Kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
This is not as good as has been
02-09-2011 9:21 AM
03-09-2011 11:14 AM
03-09-2011 11:39 AM
Fri eve 1149 380
Thur 805 380 Seems wrong somewhere
04-09-2011 7:40 AM
05-09-2011 2:29 PM
Looks like it jumped up to 1250 at about 8pm last night, have you noticed an improvement there? Should be working a lot better now, hopefully.
05-09-2011 5:52 PM
Download speed 1536 with a noise margin of mostly 8 since 07-17 this morning no disconnects as far as I know Should I reboot the router ?? or best left until to-morrow ?
Regards Ed
05-09-2011 6:53 PM
If that says 1250kbps/1.25Mbps I suggest disconnecting from Plusnet using the router's web interface, then reconnect. There should be no need to reboot the router (which would cause a re-sync and might lead to a lower sync speed).
05-09-2011 7:35 PM
Current 1.25 mb I have in fact rebooted and now have conn speed 1920 and noise 6
Speed now 278 down 380 up Will probably have to just wait
05-09-2011 8:14 PM
06-09-2011 9:41 AM
• Detailed Log
Troubleshooting – DSL Diagnostics
General Information
DSLAM: Country: {0x0F} Vendor: {ALCB} Specific: {0x00}
DSL Line (Wire Pair): Line 1 (inner pair)
Downstream Rate Cap: 8128 kbps
Downstream Atten. at 300kHz: 69.8 dB
Uncancelled Echo: -12.2 dB Ok
VCXO Frequency Offset: 25.0 ppm Ok
Final Rx Gain: 34.5 dB Ok
Impulse Noise Comp. Tones: 0 Ok
Excessive Impulse Noise: 0 Ok
Impulse noise protection: 0.55
Delay of latency path: 4.00 ms
Training History
Downstream Upstream
Time Line Rate Max1 Max2 Max3 Mgn1 Mgn2 Attn Pwr CRCs FECs INP DLY Rate Max Mgn Attn Pwr CRCs FECs Mode Vendor State Exit Code Echo VCXO Rx Gain INC Tones
2011/09/05 20:50:46 BST 1 1536 1548 1360 1360 6.1 -3.0 69.5 16.5 6761 26007 0.60 4.00 448 592 10.0 31.5 11.9 1431 1521 G.DMT Annex A Alcatel 230/105 ERR_LOF_LIMIT -16.1 24.8 34.5 0
2011/09/06 04:56:32 BST 1 384 412 656 656 6.8 8.0 69.5 12.9 8 897 0.57 4.00 448 592 10.0 31.5 11.9 0 16 G.DMT Annex A Alcatel 230/105 RETRAIN_HIGHER -18.4 24.0 34.5 0
2011/09/06 09:35:12 BST 1 1696 1708 1440 1440 6.1 7.0 69.4 16.9 148 13996 0.55 4.00 448 596 10.0 31.5 11.9 2 36 G.DMT Annex A Alcatel 229/103 N/A -12.2 25.0 34.5 0
Notes:
Time Time of last update
Max1 Max. rate at start of connection
Max2 Current or final estimated max. rate
Max3 Current or final estimated max. rate without INC
Mgn1 Noise margin at start of connection
Mgn2 Current or final noise margin
State Internal training state
Exit Code Cause of retrain
INP Impulse noise protection
DLY Delay of latency path
Bitloading
