Unable to send mail
- Unable to send mail
Unable to send mail
05-02-2008 7:36 AM
I seem unable to send mail in O.E this morning
The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was '>'. Subject 'Fw: Stair gates', Account: 'mail.plus.net', Server: 'relay.plus.net', Protocol: SMTP, Server Response: '501 <>>: missing or malformed local part', Port: 25, Secure(SSL): No, Server Error: 501, Error Number: 0x800CCC79
I will try somewhere else
Message 1 of 5
(1,564 Views)
4 REPLIES 4
Re: Unable to send mail
05-02-2008 7:57 AM
The PN mail servers don't support SSL. Disable SSL, and you should be OK again. (You can use authentication if you choose/require, but authentication is quite different from SSL)
Message 2 of 5
(472 Views)
05-02-2008 8:02 AM
Thanks. but How do I do that ?? and i didnt realise it was enabled
Message 3 of 5
(472 Views)
05-02-2008 9:05 AM
Quote Secure(SSL): No
SSL is already disabled looking at that.
Quote The rejected e-mail address was '>'
It looks like you are trying to use an incorrect mail address, check the recipient list and then check the address you are sending from.
Message 4 of 5
(472 Views)
05-02-2008 11:13 AM
Done nothing and it seems O.K now ,but had a look at my Webmail and some mails I want are marked as spam so how can I stop that?? Thank you
Message 5 of 5
(472 Views)
