UPnP (Universal Plug and Play) ????
- UPnP (Universal Plug and Play) ????
19-12-2011 3:09 PM
Log into your router and turn on UPnP (Universal Plug and Play), most routers have this option in the Administration tab.
The goal is to have an OPEN NAT in order to host Spec Ops games and get a wider selection of MP matches to join.
Also ensure that under your security options that Anonymous NAT Redirection is allowed and is not filtered. This may also be referred to as 'Filter InternetNAT Redirection' - in which case you want this disabled.
Thanks for any feedback
Re: UPnP (Universal Plug and Play) ????
19-12-2011 3:11 PM
19-12-2011 3:36 PM
UPnP doesn't seem to work so well for BF3/MW3 but we have published a guide on how to improve performance on those games here: http://community.plus.net/library/gaming/increasing-gaming-compatability-with-the-thomson-tg585v8-xb...
Hope that helps, please let us know if not.
19-12-2011 3:57 PM
19-12-2011 5:06 PM
21-12-2011 10:25 AM
21-12-2011 10:44 AM
We've seen this happen a few times, but we've now got a way around that. I can do it for you remotely, just give me a few mins.
Jojo
21-12-2011 10:48 AM
21-12-2011 11:03 AM
21-12-2011 11:04 AM
21-12-2011 11:10 AM
21-12-2011 11:24 AM
From what we know this should stay open now, if it doesn't let me know. We have seen issues when torrents were run but that tended to be just happening on the first update, not the one I just did.
Jojo
23-12-2011 11:40 AM
23-12-2011 11:45 AM
that's very odd, it seems to have worked for the others. I'll ask our router guru to check it out for you.
Jojo
23-12-2011 11:50 AM
