Thomson 585v7 or 2Wire 2700
- Thomson 585v7 or 2Wire 2700
20-05-2010 2:40 PM
Currently running the Thomson 585v7 and syncing a 2.5mbit with a fairly long line (4.1km, 56dB downstream attenuation). I've managed to get hold of a 2wire 2700 I could use, was just wondering what peoples opinions/experiences are with them?
Kitz reckons my theoretical maximum sync rate would be 3712kbps!
Re: Thomson 585v7 or 2Wire 2700
20-05-2010 3:14 PM
-- gyre --
20-05-2010 3:19 PM
20-05-2010 3:34 PM
20-05-2010 3:39 PM
20-05-2010 3:54 PM
I'm using firmware version 5.29.107.19 and my downstream SNR is 6db (see attached screengrab).
Some good info on the 2Wire here.
20-05-2010 3:59 PM
To throw another one into the mix, I also have a ST510v6 here which can be tweaked with DMT Tool.
Choices choices!!
20-05-2010 6:23 PM
Any particular settings you had to setup for it to sync? Just plugged it in and left for 5 minutes or so and it was unable to sync. Was getting alot of these in the event log:
INF P0000-00-00T00:02:45 hurl err=0 name=PHY_NONE clear
INF P0000-00-00T00:02:57 hurl err=0 name=PHY_NONE detect
20-05-2010 6:35 PM
Quote Any particular settings you had to setup for it to sync?
Nope, it should synch with those settings.
Don't take this the wrong way, but you have got the line plugged into the correct socket on the 2700, the DSL one NOT the one marked Phone Lines ( they will both take an RJ11 IIRC ).
Assuming thats ok , any chance of trying it on someone else's DSL line to check that the 2700 is OK. Even with your PlusNet username/password it should at least synch ( Broadband(DSL) Led Solid green ) on any line with DSL active.
20-05-2010 6:44 PM
The router should sync on anyl supported dsl line, so I'm surprised I didn't even get sync. I'll whack it on one of our spare adsl lines tomorrow at work.
Sync speed has dropped a bit from trying it tho, happy days!
20-05-2010 6:51 PM
The target snrm started off at 6... which is what the other modem left it at... and gave a lovely high sync, but overnight jumped to 9. I've never been able to get it back down to 6 in the last 6 months
-- gyre --
20-05-2010 7:12 PM
20-05-2010 7:19 PM
Can't get your 2Wire link to work at the moment
Quote from: Bob I have both devices and the 2Wire wins hands down for me. It synchronises at a higher rate, retrains quicker when the sync is lost, and my home network sharing/media extenders work flawlessly (they often play silly [Censored] when I'm using the Thomson and can't see each other). The only problem I have with the 2Wire is the fact that it sometimes throws a wobbly when there's a lot of torrent traffic passing through it (this isn't too regular an occurrence though and it's certainly more than capable of 'doing' torrents).
20-05-2010 8:13 PM
Quote from: Apprentice Can't get your 2Wire link to work at the moment
Try again, I'd pasted the URL twice.
20-05-2010 8:31 PM
@bob, you could always turn the 2700 into just a modem, and put a real router in front of it that would survive torrents.
-- gyre --
