This is beyond ridiculous! Speed drops!
- This is beyond ridiculous! Speed drops!
- « Previous
- 1
- 2
- Next »
Re: This is beyond ridiculous! Speed drops!
04-09-2013 4:45 PM
dick:quote
04-09-2013 5:14 PM
04-09-2013 11:39 PM
Quote from: ReedRichards
Quote from: spraxyt It looks to me like you are on a 21CN WBC connection but connecting using the ADSL1 protocol.
I am curious to know how you figure that out. Is it possible to get such a high upstream speed on ADSL1 protocol?
Yes, on 21CN as Matt commented uncapped upstream is available on both ADSL1 and ADSL2/2+. Unusual having it on ADSL1 though.
05-09-2013 6:30 AM
Sorry to but in again but if you are on ADSL1 on 21CN do you get the IP Profile immediately tracking your downstream sync rate at a fixed percentage thereof. Or are you stuck on the old system where upward changes are not immediately tracked and the IP Profile values are quantized? That was quite a curse and I am glad to be rid of it.
05-09-2013 9:29 AM
Another difference from 20CN ADSL1 is that the diagnostic speed test runs the upload section - we've used that fact a few times in the past to confirm if someone is on 20CN ADSL1 or 21CN ADSL1.
05-09-2013 1:14 PM
Hoping the regrade has made a difference? It completed this morning so I hope there's been an improvement.
05-09-2013 6:37 PM
I am really impressed by the level and quality of your support.
Regards
Warren
14-09-2013 11:20 PM
15-09-2013 9:14 AM
its highly possible yours is acting up,
you mention that your connection speed changes to unusably low speeds yet your router stats are suggesting the connection has been stable for days, are you using some speed test website to determine there is a problem?
you mentioned that you had problems with blocked ports for ages then suddenly didn't and now again do, that means either you changed something on the router or its somehow changing what it does on its own, if its the latter then that would indicate its developing a fault.
lastly you don't mention what router your using
but clearly its got a problem with errors suggesting something isn't setup properly in your flat.
15-09-2013 5:20 PM
17-01-2014 4:15 PM
- « Previous
- 1
- 2
- Next »
