ThinkBroadband Quality monitor results and possible time-of-day issue
- ThinkBroadband Quality monitor results and possibl...
07-01-2014 2:17 PM
Some advice please, I seem to have bursts of poor service:
I'm looking after a small office LAN with a Plusnet internet connection.
I'm getting a lot of grumbling about poor internet service here, however nothing definite and my line stats appear stable. There are times when regular web access becomes incredibly slow, or when status emails from a NAS box fail to arrive.
Thinkbroadband's quality monitor is giving me reports like this:
Now the odd thing is that mostly this stuff is happening out-of-hours, however I am carrying out backup jobs over VPN after midnight and some days it is bad enough to prevent VPN access.
I've opened a series of tickets with Plusnet, however they generally fizzle out as I get referred to the broadband fault process and some of the tests on that would seriously inconvenience me for example using a substitute router would require me to replicate the DHCP settings on the substitute, not a trivial task.
Message 1 of 7
(1,674 Views)
6 REPLIES 6
Re: ThinkBroadband Quality monitor results and possible time-of-day issue
08-01-2014 10:02 PM
Interesting....have you an idea of noise margin, error seconds, fec errors, crc errors whilst experiencing this packet loss.
Is a business grade router?
Try the BQM with the internal LAN disconnected overnight, the router may be busy routeing (backing up maybe) and just not replying to the TBB BQM pings.
Can we have a description of the setup (no off PC’s, switch’s NAS's Server's etc)
IAn
IAn
Message 2 of 7
(580 Views)
09-01-2014 8:55 AM
7 PCs that should have been off at the time, one NAS box (Linkstation WV2.0TL) one switch, one additional WiFi access point.
Router is a Draytek 2600X.
Telephone socket is fitted with faceplate filter.
Speed is 4640000 SNR 7.0 Attenuation 49.5 and at this time I believe those figures to be stable though the line has given problems in the past.
If the backup job was running it would have started at 1am and lasted less than 15 minutes, currently it isn't running.
Message 3 of 7
(580 Views)
09-01-2014 8:59 AM
Message 4 of 7
(580 Views)
09-01-2014 9:31 AM
Which exchange are you on? Have you looked at whether fibre is available?
Message 5 of 7
(580 Views)
09-01-2014 1:01 PM
Quote from: oliverb I've opened a series of tickets with Plusnet, however they generally fizzle out as I get referred to the broadband fault process and some of the tests on that would seriously inconvenience me for example using a substitute router would require me to replicate the DHCP settings on the substitute, not a trivial task.
You need to run through that process. We ask that you try with a different router to rule it out. If we send an engineer and it turns out to be the router, a charge will apply, hence the test. If you really can't swap out the router and will accept that risk, let us know.
Kelly Dorset
Ex-Broadband Service Manager
Message 6 of 7
(580 Views)
09-01-2014 1:07 PM
I just double checked some stuff and you're on a pretty slow line, and your pn line profile is set too high. This means that when your back ups are running, it's probably flattening any other activity. With the profile set right, the traffic management should look after your VPN etc.
Let me know if that's any better.
Kelly Dorset
Message 7 of 7
(580 Views)
