Target SNR reset [Fixed]
- Target SNR reset [Fixed]
06-09-2011 9:19 AM
Please can someone at Plusnet reset my connection back to 6dB?
Re: Target SNR reset
06-09-2011 9:59 AM
The problem could be this caused from here: http://status.aa.net.uk/apost.cgi?incident=1149
06-09-2011 10:16 AM
The problem has got nothing to do with Plusnet, it's BT's DLM that is the culprit. Also, I've got a long line so not on ADSL2+ as it doesn't offer any benefit in terms of connection speed and by all reports I've read the DLM equivalent on ADSL2+ is even more shaky.
Fibre is due December 2011, and they're in the process of digging up the pavement near to my local cabinet. This has possibly affected the noise levels on my connection, and may be the cause of the increase in target SNR.
I thought Plusnet staff had a shiny button to get target snr reset, so if anyone there spots this thread I would be appreciate it if they could press it.
06-09-2011 10:21 AM
Plusnet please sort out BT on ADSL2+ 21CN DLM at my exchange!
06-09-2011 10:44 AM
06-09-2011 11:03 AM
@goldenadsl,
With all due respect, if you have already raised two tickets for your problem please don't hijack this thread. Whilst I appreciate your empathy with my problem, yours is a different issue as you're on ADSL2+. I don't imagine PN staff will prioritise your problem as you have a perfectly usable connection of over 8M, whereas I am currently struggling to reach a minimum spec of 2M.
Plusnet staff - any response would be appreciated, even if all you can tell me is to wait and hope.
06-09-2011 11:13 AM
06-09-2011 11:25 AM
I wasn't suggesting that you should accept a connection speed of sub 8Meg on an ADSL2+ connection, merely trying to politely say that your further responses are potentially distracting for any Plusnet staff who might read the thread and be able to help me.
You are hijacking my post to promote your own issue, and I would appreciate it if you could refrain from any further responses unless you have anything to add that might help.
06-09-2011 11:30 AM
06-09-2011 11:35 AM
06-09-2011 11:39 AM
Quote You are hijacking my post to promote your own issue, and I would appreciate it if you could refrain from any further responses unless you have anything to add that might help.
I give in. Where's the smiley for 'backing my head against a brick wall'
06-09-2011 11:42 AM
06-09-2011 1:12 PM
I've decided to go down the official support route and raised a question via the 'Help and Support' page (Question #46262911).
I notice that Adam Walker responded to a similar request recently
http://community.plus.net/forum/index.php/topic,97892.msg832790.html#msg832790
06-09-2011 1:22 PM
06-09-2011 1:29 PM
The post you linked to was mine!
