TP Link TD-W8960N Router
- TP Link TD-W8960N Router
31-12-2014 4:04 PM
Hi Guys,
I have just put in my order for Plusnet Unlimited Broadband + Home Phone.
Although I included the Techniclor Router in the order I was wondering if my old router is compatible to use.
I have the TP-Link TD-W8960 N. Wireless N ADSL 2+ ver.1.6
Do you think the Tp Link would hold connection better than the Technicolor?
If compatible do you guys know what settings I need to put in for Login.for example User Name,Password etc.
Thank for the help.
Thank for the help.
Message 1 of 4
(884 Views)
3 REPLIES 3
Re: TP Link TD-W8960N Router
31-12-2014 4:46 PM
Should be fine, just use <username@plusdsl.net> as the user & your bb password for the password.
Message 2 of 4
(496 Views)
31-12-2014 4:48 PM
Thats the router I use PN user name is of the form "username@plusdsl.net" and password is whatever you set up when you joined PN. Connection type is PPOA -don't think I had to input anything else - it holds my connection very well at low SNRM of ~ 3db
EDIT -And I get good wireless coverage throughout the house.
Message 3 of 4
(496 Views)
31-12-2014 6:51 PM
Thanks guys,much appreciated....
Message 4 of 4
(496 Views)
