Sync speed has been gradually dropping.
- Sync speed has been gradually dropping.
29-04-2009 10:25 AM
My best sync speed has been gradually dropping from about 2500K a couple of months ago to 1760Kbps today. I normally reboot the router regularly. The current stats are:
noise margin upstream: 17 db
output power downstream: 16 db
attenuation upstream: 31 db
noise margin downstream: 11 db
output power upstream: 11 db
attenuation downstream: 56 db
I have tried changing the microfilter and used a different router but there is no significant difference in sync speed (actually this was a bit slower). I only have one phone and no sky boxes or alarms to mess things up. I have a very old BT master socket without a test socket. I haven't made any changes to my setup (and I can't see how this would cause a slow and gradual change in the sync speed).
I have raised a ticket and PN say they can't find a specific fault but the sync speed should be higher. I tried the BT quiet line test and there does not seem to be much noise on the line (just hiss from the phone itself I think).
I have never managed to get a BT speed test to complete. It always get stuck at 96%!
Does anyone have any other ideas?
Re: Sync speed has been gradually dropping.
29-04-2009 10:32 AM
Given that you're getting at least some hiss on your telephone line, it certainly wouldn't hurt to get something raised with BT Retail, or whoever your voice supplier is.
29-04-2009 10:53 AM
29-04-2009 11:00 AM
Worth trying.
29-04-2009 1:48 PM
29-04-2009 4:23 PM
29-04-2009 4:34 PM
![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
29-04-2009 4:39 PM
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
29-04-2009 5:22 PM
29-04-2009 7:55 PM
