Slow speeds afternoon and evening
- Slow speeds afternoon and evening
Re: Slow speeds afternoon and evening
21-10-2008 4:41 PM
With regard to capacity, the next segment was due to be lit by the end of the month but we're now getting this moved forward - no dates yet, but there will be updates as soon as we know more. That should sort things out.
As for THN-AG3 there's a thread on it here.
Hope that helps, sorry for the hassle.
21-10-2008 8:28 PM
![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
22-10-2008 9:30 AM
27-10-2008 9:49 AM
I seem to be connected via the new pcl-ag02 gateway.
Thanks.
27-10-2008 10:20 AM
27-10-2008 11:04 AM
Quote from: orbrey They certainly shouldn't be, and on checking your profile I found it to be at 4.5Mb - are you still getting the slower speeds?
Yes, I am. See test results. A number of tests through Speedtest.net show the same.
27-10-2008 11:54 AM
There's only really the usual things you could try to get the profile back up - router into master socket, filters on everything etc etc.
27-10-2008 7:59 PM
Even outside busy evening times the speed recently is consistently 3700 plus or minus 100 which makes me think there is a limitation somewhere.
Are you really saying that a profile of 4.5 Mbits (with sync greater than 5.5) should never get more than 3700 kbps at any time of day or night, which is what I have tested it at recently.?
27-10-2008 8:37 PM
Quote I realise it's dropped a bit from what it was, but unfortunately that happens over time given the infrastructure ADSL runs on.
Orbrey... Could you please claify this. I have a rock solid 4.5-5.0meg profile. Normally usually get 4200-4300 (4500), and 4700-4800(5000). I do not agree that the speeds decrease with time, and would welcome clarification. Last Night my speeds were fine, and tonight, much to my surprise, all OK. I do hope this now continues, and everything gets back to normal. I can resonably expect a drop of around 400-500kbps at peak times, compared to off peak, as long as its not laggy.
Today 20:35 4540 kbps (568kB/s) 365 kbps (45.6kB/s) Share
Yesterday 21:26 4706 kbps (588kB/s) 367 kbps (45.9kB/s) Share
Yesterday 20:12 4731 kbps (591kB/s) 382 kbps (47.8kB/s) Share
Yesterday 18:18 4754 kbps (594kB/s) 382 kbps (47.8kB/s) Share
Yesterday 15:22 4671 kbps (584kB/s) 382 kbps (47.8kB/s) Share
Yesterday 14:04 4693 kbps (587kB/s) 382 kbps (47.8kB/s) Share
Yesterday 09:34 4728 kbps (591kB/s) 386 kbps (48.3kB/s) Share
Saturday 20:50 1735 kbps (217kB/s) 265 kbps (33.1kB/s) Share
Saturday 20:24 2533 kbps (317kB/s) 264 kbps (33kB/s) Share
BTW, have you any updates on the gateway thats not providing any stats THN-AG3 I think,
28-10-2008 10:36 AM
Quote I do not agree that the speeds decrease with time, and would welcome clarification.
It depends on the line itself - joints that move in the wind, weather related issues - it can all add up but if a fault isn't found (ie if the connection doesn't actually drop and/or the speed decreases slowly enough that the fault threshold rate is lowered to compensate rather than the sync speed dropping below it).
28-10-2008 8:34 PM
Today 20:30 3109 kbps (389kB/s) 321 kbps (40.1kB/s) Share
Today 19:58 4275 kbps (534kB/s) 385 kbps (48.1kB/s) Share
A drop of over a meg in the space of 1/2 hr, is this classed as normal at peak times for a 5meg profile?
![Huh Huh](/html/@E2297E1574AC8AB2FE5882A8865382BF/images/emoticons/huh.gif)
28-10-2008 9:08 PM
B.
29-10-2008 8:23 AM
Thanks for the reply. I am on Legacy PAYG. I am now wondering If Plusnet have overstretched themselves, or is this ongoing issue with upgrading software on the edge routers causing issues. THN-AG3 has not been reporting for ages, ??is it accepting connections, as I can never get on it, and also another gateway appears to be strangely quiet as well last night. I just want things to get back to as they were, even my wife, who is normally happy when browsing is compaining sites are taking an age to load up, and it takes alot for her to complain about the broad band.
Chris
31-10-2008 12:39 PM
I rebooted and got connected via the ptn-ag2 gateway (as opposed to pcl-ag02) and had an immediate jump in downstream transfer speed from 3.7 to 4.2 Mbit/s but this seems to have been a false dawn as it hasn't improved despite a few rechecks at different times of day/night.
I have been resynced at 6912 for more than 80 hours, with a consistent and stable noise profile throughout of 6dB plus-minus 0.2, and an apparent BT profile of 6000 kbits/s. (See attached pictures).
Yet, I still cannot get more than 4.2 Mbit/s download. What is wrong? Is it in the Plusnet system?
31-10-2008 1:30 PM
In all honesty, it's quite possible that what you're seeing is exchange congestion rather than issues with our bandwidth infrastructure.
4.2Mbps on a 6Mbps isn't actually that bad.
