Set line to ADSL1
- Set line to ADSL1
Set line to ADSL1
03-01-2016 5:37 PM
Please set my lime to adsl1. I am having heaps of issues with adsl2 and 2+ that the bt open reach engineers can't work out and would like to set it to adsl1 whoch has worked in the past.
Many thanks,
Lewis
Many thanks,
Lewis
Message 1 of 5
(1,069 Views)
4 REPLIES 4
Re: Set line to ADSL1
03-01-2016 7:27 PM
What router do you have? It might be possible to set it at your end.
Message 2 of 5
(595 Views)
03-01-2016 10:26 PM
Plus net Hub one. I have tried but not aware of how to do it.
Message 3 of 5
(595 Views)
04-01-2016 12:05 AM
Adsl1 is less flexible than ADSL 2.
You really do need the issue discussed in your other thread resolving. I've asked the mods to merge the threads to ensure continuity in understanding your issues.
Message 4 of 5
(595 Views)
04-01-2016 10:03 AM
Ok will do, don't worry about the request.
Many thanks.
Many thanks.
Message 5 of 5
(595 Views)
