SNR check
XenoGuy
SNR check
I'm not really a speed freak, although I do wish I had access to FTTC, as long as I've a steady connection, I'm happy.
Although, for a few months my SNR has been a 12 rather than a 6. I had a problem earlier this year with my SNR wouldn't rise from a 3, therefore OR had to manually set it to a 6. So I thought 6 was my default.
Last night around 9pm, I was disconnected, not sure why, bare in mind my SNR is a 12 so, I find that high should be stable... Then at 4am I had a PPPoE reconnect.,,,
Can someone check my default SNR please.
18 REPLIES 18
MatthewWheeler
Fixes: 480
Re: SNR check
At the moment your on a 12db SNR target.
It looks like DLM has increased your target to this over the past few months.
We'd need to find the cause before doing a reset as the SNR target could easily go back to where it is now.
 Matthew Wheeler
Fixes: 162
Re: SNR check
Can you please take a look at the speed issues thread and post the requested information here.
Is the phone line quiet.  Dial 17070 option 2.
XenoGuy
Re: SNR check
Line is silent
1, Looks poo-poo
Uptime: 6 days, 20:47:08
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 888 / 9,891
Data Transferred (Sent/Received) [GB/GB]: 6.25 / 79.52
Output Power (Up/Down) [dBm]: 12.0 / 0.0
Line Attenuation (Up/Down) [dB]: 15.1 / 30.0
SN Margin (Up/Down) [dB]: 13.5 / 11.9
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 129,357 / 0
FEC Errors (Up/Down): 18,867 / 1,064,190,078
CRC Errors (Up/Down): 780,967 / 8,196,404
HEC Errors (Up/Down): 260,592 / 4,977,403
2. Even worse
😧 6.14Mbps
U: 0.53Mbps
Ping: 38ms
3.
Estimated line speed:
Current line speed:
8.7 Mbp
My Line Attenuation is 30, which means I can/could get ~13Mbps sync.
What would cause PPPoA drops? Had one today.
Fixes: 162
Re: SNR check
With or without xDSL drops?
If it is without, then that could be BTw engineering, PlusNet load balancing or changes being made to your line profile following a resynch.
If with then because of it!  Cool
Line noise?
Are you plugged into the master socket?  Is there any extension wiring?
aesmith
Fixes: 4
Re: SNR check
Isn't that quite a high error rate?  If the line goes through bad spells a lower noise margin target will mean more drops.
Tony
Fixes: 162
Re: SNR check
Indeed the error counts are grotty.
@XenoGuy,
Is the phone line quiet?  Dial 17070 option 2.
Quote from: XenoGuy
Was that a typo?  You should be using PPPoA.
There will be a reason why the target SNRM has been raised - the cause needs to be identified and fixed.
Is this a TG582n router?  If yes, what version of firmware has it got?
XenoGuy
Re: SNR check
Quote from: Townman
I did say quiet
Quote from: Townman
Yes,  had Be Un Limited for so long, I always forget.
Quote from: Townman
How?
Quote from: Townman
Yes and 10.2.2.B
Had another PPPoA disconnect too.
XenoGuy
Re: SNR check
The only things I have connected to the line via doubled filtering are:
- BT Big Button 200 Phone;
- US Robotics Modem USR5637;
- Brother MFC-7320 Printer
aesmith
Fixes: 4
Re: SNR check
What do you mean by "doubled filtering"?  Ideally would it be possible for you to try with only the DSL router and the phone connected to the line?  Even better connect the microfilter into the test jack socket.  The idea is to eliminate any possibility that your equipment is contributing to the issue.
Tony
XenoGuy
Re: SNR check
I have no test socket, I'm in a flat - it surprises me that everyone thinks every building has bt test sockets by default!
By double filtering, I mean, DSL line in 1st filter, plug a 2nd filter into the 1st filter and plug my stuff into the 2nd filter - had this setup since 2007, so it's not that.
Fixes: 162
Re: SNR check
What do you mean by "your stuff in the second filter"?
Just the phone stuff?
Just the router?
Everything?
aesmith
Fixes: 4
Re: SNR check
Quote from: XenoGuy
The test socket is on the back of the normal BT master socket, if you have your own telephone line then you should have this, surely?
http://www.plus.net/support/broadband/master-socket-guide.shtml
Tony
cedlor
Re: SNR check
Quote from: XenoGuy
8 year old filters ?  Maybe one or both has gone bad  -did you get a new one from PN that you can try.
Pictures of your unusual set up might help
XenoGuy
Re: SNR check
Quote from: cedlor
Not 8 year old filters, I change them every 6 months...I mean someone suggested, when I joined Be, that as DSL2  was prone to noise, double filtering will help, so I've stuck with that since.
Truth be told, I managed to hold a 3.5 SNR for months with BE....
