Routing between two subnets
- Routing between two subnets
25-08-2013 1:01 PM
I am trying to connect my private CCTV network to the internet for remote monitoring..
The VMS server is running windows server which has a physical lan interface and wireless interface. I have configured the wireless interface to connect to the Thomsons TN585v8 router and enabled ICS so now the windows server has internet access via 192.168.1.65 the physical lan interface is configured with DHCP scope 192.168.45.0 and connected to a switch.
when i connect a laptop to the switch i can obtain a IP address 192.168.45.30 and i am able to resolve dns hostnames such as www.google.com but i am unable to ping it.. i suspect i need to put a static route on the router but not sure what routes needs to be added..
Please find attached a simple network diagram and a route list of the TN585V5 below... I would be greatful for any advice as my networking knowledge is somewhat rusty..
{admin}=>ip rtlist
Label Destination Gateway Interface Mtc Admin Oper
10.0.0.138/32 127.0.0.1 loop 0 UP [UP]
10.0.0.255/32 127.0.0.1 loop 0 UP [UP]
87.212.33.109/32 127.0.0.1 loop 0 UP [UP]
127.0.0.1/32 127.0.0.1 loop 0 UP [UP]
192.168.1.254/32 127.0.0.1 loop 0 UP [UP]
192.168.1.255/32 127.0.0.1 loop 0 UP [UP]
255.255.255.255/32 127.0.0.1 loop 0 UP [UP]
195.166.128.183/32 87.212.33.109 Internet 0 UP UP
212.159.6.9/32 Internet 10 UP UP
212.159.6.10/32 Internet 10 UP UP
10.0.0.0/24 10.0.0.138 LocalNetwork 0 UP [UP]
192.168.1.0/24 192.168.1.254 LocalNetwork 0 UP [UP]
0.0.0.0/0 87.212.33.109* Internet 10 UP UP
{admin}=>
{admin}=>ip rtlist
{admin}=>
Message 1 of 2
(689 Views)
1 REPLY 1
Re: Routing between two subnets
25-08-2013 2:25 PM
looks like i've managed to fix it myself...
following command required on the router..
ip rtadd dst=192.168.45.0/24 gateway=192.168.1.65 intf=LocalNetwork
then i enabled RRAS on windows server for Lan Routing...
Message 2 of 2
(377 Views)
