Restricted for Off-Peak useage
- Restricted for Off-Peak useage
06-01-2009 8:52 PM
Hi all, Is there a limit for the amount of Off Peak bandwidth you use. A couple of days ago Off-peak was its usual 3 to 4 mb downloading but peak times only about 130 kbps d/l and 55/60 kbps u/l. Down all the usual checks but no faults. I had used 150gig off peak but only 8 gig peak with a 15 gig limit on Premier 1. I raised a ticket and the reply was I had exceeded my limit and was restricted. BUT I am only restricted peak times when I have plenty of bandwidth left( when it takes 30/40 seconds to load a single page) but I'm not restricted Off where I've used lots & lots of gigs.
I have had no emails warning me of the restriction but when I have got to 11 gig of my peak usage before I have had the email warning me.
Is this a new thing of limiting off peak as I have never been close to 150 gig before and probably won't again.
Many thanks Derek.
Many thanks Derek.
Message 1 of 7
(1,379 Views)
6 REPLIES 6
Re: Restricted for Off-Peak useage
06-01-2009 8:56 PM
There are no limits imposed for off-peak traffic, but is limited by the available bandwidth on the BT centrals - i.e. it is shared amongst all users.
There are restrictions during peak time but again you share it with others so if a lot of people using things like P2P the overall speeds people get will vary.
Message 2 of 7
(579 Views)
06-01-2009 9:20 PM
Thanks Peter, This is the reply I got from my ticket:- (at least I am only restricted til tomorrow)
Key: Peak usage Peak usage: 8.07GB 4pm - Midnight
Key: Off-Peak usage Off-peak usage: 154.03GB Midnight - 4pm
Total usage: 162.1GB
This will reset on your next billing date of 07/01/2009. I hope this helps and please let us know should you require any further assistance. You can do this by either replying to this ticket at http://contactus.plus.net or by calling us on 0114 2965198.
But the thing what annoyed me the most was that I had no warning email from Plusnet.
Derek
Derek
Message 3 of 7
(579 Views)
06-01-2009 9:23 PM
That doesn't say you are restricted?
Message 4 of 7
(579 Views)
06-01-2009 9:44 PM
Hiya,
On Broadband Premier, there shouldn't be any management being applied during off peak times other than the rate limits which are applied to all users of the same product on advanced protocols such as P2P and Usenet.
Message 5 of 7
(579 Views)
06-01-2009 10:01 PM
I did the speedchecker before 4pm and came back at 3.5mb done it twice tonight and both at about 128 kbps d/l and 60 u/l. It takes about 4 minutes to do the speedchecker it's so slow. Take for ever to even see a plusnet page.
Message 6 of 7
(579 Views)
06-01-2009 10:05 PM
Looks like you are been incorrectly throttled, I'd reply to the ticket seeking clarification if you can.
Message 7 of 7
(579 Views)
