Reducing SNR
- Reducing SNR
Reducing SNR
27-11-2009 3:55 PM
Hi
Please could someone change my
SNR from 13dB to 6dB
turn my Interleaving off
remove the banded profile
many thanks
Angus
username horror
many thanks
Angus
username horror
Message 1 of 3
(1,270 Views)
2 REPLIES 2
Re: Reducing SNR
27-11-2009 5:02 PM
Has something been resolved recently with your internal wiring or line? I ask because we can request this, but if it's likely to be reinstated then there's no point (and BT are loathe to do it more than once so theoretically could make the situation worse).
What are your line stats?
Message 2 of 3
(361 Views)
Re: Reducing SNR
27-11-2009 9:32 PM
Hi
My internal wiring and line are fine always have been for the last 4years or so. when moving to adsl2 my ping doubled think this was due to interleaving being turned on. i would like the SNR Margin lowered so that the line sync speed will be higher and the interleaving turned off so my game ping will half. I did raise a ticket a while ago about packet loss but see other people had the same fault this seems to have stopped now.
ADSL Status Mode State Up Speed Down Speed SNR Margin Loop Att.
ADSL2+ SHOWTIME 888800 15231400 13.0 17.0
when ADSL2 first came on the modem would sync at 1meg up 19meg down, only BT lowered it, and doubled my ping
Message 3 of 3
(361 Views)
