Rather confused!!
- Rather confused!!
- « Previous
- 1
- 2
- Next »
Re: Rather confused!!
22-04-2013 5:15 PM
Thank you!
What needs to go with router when I send it back?
Jamie
Jamie
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 16 of 21
(393 Views)
22-04-2013 5:25 PM
Everything that came with it if possible, micro-filters and power supply please.
Message 17 of 21
(393 Views)
22-04-2013 6:46 PM
As it was an FTTC router, I didn't get any micro filters
Also as you may have seen on my account that i'm downgrading to ADSL as there is no fibre availability.
Are YOU able to supply a few micro filters to connect the telephones and hubs up etc???
Would be great!!
Would be great!!
Message 18 of 21
(393 Views)
22-04-2013 7:02 PM
didn't you have them before you went to Fibre
doesn't the new build have a filtered faceplate
Message 19 of 21
(393 Views)
22-04-2013 8:41 PM
@OLDJIM. No I ordered PN fibre as a new customer (never been with PN before)
Also I chucked out all microfiltrs that Sky provided as no longer needed obviously.
Also can you (I ) put a filtered faceplate? I am planning to put the router in my bedroom where a extension socket goes (already fitted by BELLWAY)
If I put a filters faceplate in on the mast socket. Will I be able to put the router on a ext socket?
Message 20 of 21
(393 Views)
22-04-2013 8:56 PM
Only if the filtered faceplate has unfiltered terminals and that particular extension is wired from the unfiltered terminals. You'll still need a filter at that extension socket just to convert from BT socket to RJ11 even if you don't want a phone there, or if you don't want a phone there you could fit an RJ11 socket instead of a BT type. If there are other sockets on the same wire (ie. daisy chained) then you'd need filters on them if you are going to plug anything in, all told depending on what extension sockets there are and how they are wired, a filtered faceplate may be a waste of time.
You may be best waiting until you can check how it's all wired up, whether the correct cable has been used etc.
You may just as well get your self a couple of quality Microfilters that look like this? anyway. You'd need on for testing from the Test Socket should the need ever arise, and a spare is always good - should have kept your Sky ones
Message 21 of 21
(393 Views)
- « Previous
- 1
- 2
- Next »
