Ps4 strict nat
- Ps4 strict nat
Ps4 strict nat
17-09-2014 1:58 PM
Just come over from bt told was better for online gaming .on Bt. the gaming was rubbish but had nat type open .I'm using the standard router( technicolor ) the ps4 is nat type2 40+ meg download 12+ upload low ping was told to open the ports so I have still strict.trying to play cod is hopeless it's like I'm half a sec behind plus net tech support say not able to help anybody out there got any ideas or am I stuck with this for 18 months
Message 1 of 3
(597 Views)
2 REPLIES 2
Re: Ps4 strict nat
17-09-2014 3:51 PM
you can use any cable router m8 even ur bt hh technicolor routers not good for gaming even with open nat
Message 2 of 3
(366 Views)
Re: Ps4 strict nat
17-09-2014 3:54 PM
use dmz your nat will be open but only use dmz for consoles
Message 3 of 3
(366 Views)
